Question about Sirius Stiletto 2 Portable Satellite Radio Receiver
Stiletto 2 Internal Antenna broken - Am I F'ed or what?
So in my travels I must've jarred my S2 so violently that it broke the internal antenna. I know everyone complains about how weak it is, but there were a few places indoors and out, including my work that I got good reception without being hooked into the sirius headphones/port.
One day last week I tuned to listen live to find I'd lost all signal. I got an 'aquiring signal' message even outside in the middle of a field where I'd gotten 2 bars on the 3bar scale thing previously. Now, not a flicker on it or in the Antenna Aiming screen in the Devices menu. When I got home and plugged into my home port with it's own antenna, I picked up signal again.
I am absolutely sure that the problem is the internal antenna in the S2 itself is broken. Sirius Tech help first refused to acknowledge one existed. Then they said there was, but it was to communicate with the antenna in the top of their headphones (rather than the wire attaching the two). Then they acknowledged it existed, but said it didn't really work. Finally then they told me I should buy a new S2, but not expect to get any kind of decent reception thru the internal antenna with the new one. Then they pointed out that my warrenty was just expired by less than a month and then they said even if I paid them, they don't repair them.
My question is, does anyone go into the S2 units and repair the internal antennas and/or would it be too expensive/difficult to make it worth it?
Thanks
  • 3 Answers
You can try to open it and resolder is really easy but you have to be carefull when you take it a part there is many small resistors and capasitors near the antena and you will need a scope to see the wires and to solder i fixt my like that and it works fine
Posted on Jan 12, 2009
Im having the same problem :(. Also convinced its the S2 internal antenna. Did you have any luck on fixing it?
Posted on Nov 12, 2009
5 Suggested Answers
SOURCE: white square on sirius stiletto 2
I ran the stiletto device recovery program and it works again. You can find it on the Sirius website by searching for "stiletto device recovery". However, it does delete all of the content that you have saved on the stiletto.
Posted on Jul 31, 2009
SOURCE: usb connection on sirius stiletto 2 to pc
You must be sure to have satellite radio turned off in order to connect to the pc. If you are using a home dock, first make sure satellite is off and then push the "Sync" button on the front of the home dock.
Posted on Jun 03, 2008
SOURCE: Sirius Stiletto 100 - can't record as of Jan 1 2010
Hard boot fixed it... (removed battery, put it back in... shoulda tried that a long time ago...)
Posted on Jan 06, 2010
  • 7 Answers
SOURCE: sirius stiletto 100 LCD screen partially broken
I do this repair for a broken LCD on the S50's. I am on Ebay and my user name is rarey57siriusXM. Look me up I also do LCD and scroll wheel repairs for the Stiletto 10 and 100's. Cost of this repair service is $24.95 and that includes free priority mail shipping back to you on all these different repairs. Thanks
http://myworld.ebay.com/rarey57siriusxm
Posted on Feb 21, 2010
HG8245A VS HG8245: The same Wifi Signal Strength?
Probably not...... With an External Antenna, there is nothing to stop the signal, whereas with the Internal, the Signal has to penetrate the case, before it goes to wherever...... I suggest using the External for the extra distance.... With 2 way radio the clearer the area yo have the Antenna, the greater the distance.... same here.... just using different Frequencies.
May 08, 2014 | Computers & Internet
My stiletto does not get a signal. It comes in for up to 10 seconds at a time and then nothing, searching. I walked to the top of San Bruno Mountain overlooking San Francisco with no improvement in...
Does it get a solid signal when its in a docking station? Its likely that the internal antenna on the unit is disconnected. Antenna headphones would correct the issue, though they are not very durable at all. I know that our repair guy is able to fix the internal antenna, but I would ensure that is the issue first. Try plugging it into a home dock, car kit, or boombox to see if it works through one of those antennas.
May 26, 2011 | Sirius Stiletto 2 Portable Satellite Radio...
My phone was dropped and now it wont recieve service
If you don't have an antenna sticking out of the phone then you probably have an internal one. When you dropped it, you could've damaged the internal antenna or if you do have an external antenna it could be damaged on the inside.
May 03, 2011 | Sanyo Cell Phones
Get it repaired at Westek
This problem is not caused by poor solder joints. It's caused by a defective part. We sent a "marked" defective unit to the repair shop mentioned above and upon its return, disamantled the GPS receiver assembly and made the following evaluation:
1. The shop did NOT replace the defective component causing the initial problem in the 1st place. The defective part was STILL in the circuit.
2. The shop placed a wire jumper between the internal antenna and the external antenna port. This type of modification places a +2.5VDC bias on the internal antenna and essentially shorts the internal antenna to the external antenna (when connected), giving unpredictable results. It also affects the circuit impedance and signal strength. This is not the correct way to resolve this issue.
3. The defective part needs to be replaced with a higher rated part. This type of repair returns the unit to full functionality and allows the unit to properly switch between the internal and external antenna as it was intended to do by design
- Jim
SHARCNET-USA
Sep 25, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
I want to install internal antenna in samsung
test test 18:30rfv
test test test 18:31s rthsr thsty
Jun 27, 2009 | Cell Phones
Can anyone help me locate the internal wifi antenna of my travel 2428
You will need to have the laptop taken apart to be sure. Most manufacturers wrap the wireless antenna around the monitor. The only way to be sure is to find someone who has worked your model, or follow the the antenna from the wireless card inside your notebook
Jun 16, 2009 | Acer TravelMate 2424WXMi_S58 PC Notebook
Sirius Stiletto 2 constantly "acquiring signal"
This is an odd fix, but I read it yesterday after having the "Acquiring Signal" issue for a week. I put it in the freezer for 30 minutes, brought it back to my desk and now it works. I don't know why or how, but I am happy.
May 04, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
Apr 05, 2009 | Grundig YB 400PE AM/FM/SW Radio
NO SERVICE
Ok, you could maybe open the phone and look inside of it. But these antennas are just unscrewable, so no need of opening you're phone. check the antenna, is it bended ? crooked ?, broken ? If it is, you can buy other antennas on internet http://www.367net.com/product.asp?Brand=Motorola&model=V265&Type=Antenna and if it is not broken, well the problem could come from the interior of the phone, and well at that point you don't have alot of chances. Verizon said that it can be the internal antenna, but keep in mind that its maybe not true. It probably inside the phone.
Dec 27, 2006 | Motorola Mobility V265
Sirius Stiletto 2 Portable Satellite Radio Receiver Logo
653 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
