Question about Kenmore 7.5 cu. ft. / 212 liter Upright Freezer 24701
Kenmore 7.5 freezer stopped working.
After unloading it I plugged it back in the compressor hummed about 20 seconds, then a click from a relay, and the compressor stops. About a minute later compressor hums again, another 5 seconds there's a click and stops again.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Posted on Dec 14, 2012
  • Sidistik
    Sidistik Jul 10, 2014
    Relay relay hot because the compressor has a locked rotor ,youse amp prode and check for LRA amps it's wrote on compressor (locked rotor amps) if same as amp probe then definitely compressor
  • 124 Answers
SOURCE: Kenmore Upright Freezer Works Sometime
try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Posted on Nov 06, 2008
mikeh77586
  • 9 Answers
SOURCE: Kenmore Upright Freezer compressor running 6 seconds every minute
Usually the compressor runs pretty warm anyway. However if you think it's too hot I would start with the condenser coils located either under the unit or on occasion they are located on the back. The air flow across these coils as well as the airflow around the compressor must be maintained. I forgot to ask if the condenser fan is running. Check and make sure that the Fan is running and the air flow is good. Also, When you transported the unit did you move it standing vertically like it normally stands or did you lay it on its side. If you transported the unit on its side you must wait a minimum of 24 to 48 hours prior to start up or the unit could be ruined permanently. The refrigerant has to be utilized through the compressor as a gas. If the unit is on its side liquid refrigerant could be introduced into the compressor and can cause permanent damage. If this is the case I recommend that you turn the unit off at once and wait the 36 hours for the Refrigerant to settle then try it again. This transportation rule applies for any appliance That uses refrigerant, Air Conditioners etc. These units are not that hard to diagnose. The only other item that is usually a problem is the defrost timer. It is not very expensive and can also cause some of the same symptoms that you are eluding to. The defrost timer allows the freezer to periodically shut down to prevent the buildup of frost or ice on he evaporator coils and on the inside the unit. If it is defective, then the unit will either run all the time and cause the evaporator coils to freeze up or will not allow the compressor to switch on and it will not freeze like it should.
Posted on Nov 12, 2008
erpaalai
  • 999 Answers
SOURCE: compressor click
Possibly. However it sounds like the compressor is running hot which could be the relay assembly sticking with the start windings in the circuit.
Eric
Posted on Jan 24, 2010
  • 4793 Answers
SOURCE: Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Posted on Feb 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: Freezer quit (Kenmore Upright)
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 15, 2010
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
Freezer won't turn on
GIVE IT TIME SO THE THE SYSTEM COULD STABILIZE IT SYSTEM FOR A FRESH STARTUP. OR HAVE CHECK TO ITS OVERLOAD UNIT THE COMPRESSOR MOTOR.
Sep 12, 2012 | Kenmore Freezers
Hums seconds only does not freeze
If it hums then quits and hums and quits and just keeps doing this then either the compressor start relay is burned out or the compressor is seized. Unless you are capable of diagnosing this you should have a tech check it out. If it's just a relay they are relatively cheap, but if it's the compressor it could cost more than the freezer is worth.
Dec 03, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezer starts then stops
Either the start relay on the compressor is bad OR the compressor is bad.
Replace the start relay and find out which it is.
When you remove the relay you may see a burned spot on one or more of the relay terminals.
If so,it is definitely bad.
Apr 26, 2010 | GE 24.9 cu. ft. General Electric Chest...
Freezer stopped working. Unplugged and plugged
The compressor trying to start and not getting started...it could be mechanically broken or the start cap and relay could be bad...
here is a tip that will help you with that...
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Feb 22, 2010 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Compressor click
Eric
Jan 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezer compressor hums when turned on then shuts down after about 15 20 seconds. After it sits for awhile I can plug it back in and the same thing happens. Any thoughts?.
Compressor is going into thermal overload. This means the compressor won't be any good. Replacement is needed.
Dave
Aug 21, 2009 | Freezers
Relay clicks, compressor doesn't start
try replacing the relay/ overload you can buy a supco replacement there's 2 of them one covers 1/15 - 1/6 and the other covers1/3 - 1/4 its really easy to wire up and cost effective. any questions don't hesitate to contact by e-mail hvac.tech@gmail.com
May 18, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Kenmore 7.5 cu. ft. / 212 liter Upright Freezer 24701 Logo
186 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
