Question about Kenwood VR-510 Receiver
IR Reliability--Intermittent The receiver works well in all respects...but often it will not respond to IR commands. I've tried other remotes, eliminating my repeater, new batteries, etc. Nothing works. It does not seem temperature dependent as I've tried cooling the unit more and it's still an issue. Sometimes the IR actually works...but most of the time not. Any ideas on what could be causing this issue?
  • Jeremy Buckingham Jun 09, 2007
    The IR window is clean in all respects. The unit is located inside a cabinet. It doesn't seem to matter whether it's closed or open.
    No flourescent lights are even in the house let alone nearby.
    Proximity to the unit also has no impact...which means it's getting plenty of signal.
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented: http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/.
All is working great now!
Posted on Jan 13, 2009
The VR-510 uses a Radio Frequency remote not a IR (infared) remote. So it should not respond to IR remotes.
Posted on Jun 02, 2008
I ahave the same problem. You can reset the receiver but in my case it did not do anything
Posted on Jan 16, 2008
  • 883 Answers
Is the IR window on the Kenwood dirty (inside and outside)? Is the IR lens itself dirty? How about working with room lights off...any change?
Posted on Jun 09, 2007
My remote control lost it codes... wil not function on amaha amp
The IR receiver or associated components inside the amp may have failed
Sep 20, 2016 | Yamaha RX-V567 Audio video AV Receiver for...
I have a hr21-700 and bought a universal remote (logitech harmony 900) and the unit will not respond to rf commands? I went throught the setup process in the menu option, help
The DVR must be set to use IR instead of RF. The RF Blaster that comes with the remote converts the RF from the Harmony remote to IR commands.
Dec 29, 2010 | Directv HR21-700 DTV Receiver
The television has stopped responding to its remote and a cable remote.
Hello SKrokau:
Have the IR sensor (Infared Sensor) replaced in this model. It is a common failue for Sylvania televisions. The IR sensor is the device used to receive commands from the remote and relay the commands to the microprocessor for processing. The sensor is very inexpensive and the total to repair should not cost you more then (FYI) $80.00 for parts and labor.
Have a Happy Holiday!
Nov 22, 2009 | Sylvania SRT2232S 32" TV
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Your using a universal remote from what U am understanding, Two solutions for ya
1)diffrent remote all togeather from radioshack
or
2) the Tv's IR is not working
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Panasonic CT-27SL14 27" TV
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
URC-9910 remote: The RF part for this remote stopped working.
I have the same remote as yours and occasionally the RF remote is not working due the interference signal from outside or next door at certain hours.
My suggestions:
(1) To relocate the receiver and reposition the anntena for better reception of the RF signal from the remote unit.
(2) Replaced the battery.
Hope these help!
Aug 04, 2008 | One For All URC-9910 LCD Remote Control
Hp media center pc 2002 remote stopped working. The ir lights up when any key is pressed on the remote, but computer won't respond to it. tried to roll back one day but didn't fix it. Tried to roll back...
If the menu button is on the remote and the unit is not responding to remote.....
try changing batteries and clean the remote and receiver lens.
Mar 16, 2008 | Computers & Internet
IR receiver on unit not working?
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
Nov 22, 2007 | Kenwood VR-309
TV won't respond to remote(s)
I don't know of any adjustments for the IR receiver but the receiver itself could have gone bad or something may be blocking the IR lens not letting the IR signal get through. Maybe (but unusual) there may be a cold solder joint in the IR circuit. Sometimes dust will collect on the inside of the IR lens causing this problem. You can verify the operation of your remotes by holding them close to an AM radio receiver and pushing the buttons. You'll hear a popping sound through the radio speaker whenever a button is pushed. You may have to tune the radio up or down the band to pick up the remote's signal. Stargazer
Mar 02, 2007 | Toshiba 34HF81 34" TV
Kenwood VR-510 Receiver Logo
463 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
