Question about Toshiba Satellite C655-S5068 Notebook
Runs slow. I put it on hibernate when not using it, so it is on a lot. is it a cooling issue?
I have tried turning it off when not using it, still runs slow sometimes.
    Novelist:
  • 250 Answers
To fix laptop getting slow problem i would suggest to perform the following steps:
- Repair corrupt registry entries
- Remove temporary internet files
- Stop un-necesasary services
- Rwmove third party applications
If problem still exists then use a system utility tool Intel software partner Reginout for complete system optimization. WebRepOverall ratingThis site has no rating(not enough votes)
Posted on Dec 05, 2012
    New Friend:
    Problem Solver:
  • 6 Answers
Try to do a recovery ,
and dont install a lot of programs
Posted on Dec 04, 2012
Why does it take 10 minutes to get my computer out of hibernation
If you have a lot of program, or windows open when you put your computer to sleep, or in hibernation, it will take longer to wake up, as it has to load everything into memory that you were using. If your computer is low on RAM, or you're using more RAM then your system has, it will be slow due to loading up what's in virtual memory. Try closing some programs before putting your computer in hibernation. If this doesn't help, try checking your computer for malware.
Sep 19, 2013 | Toshiba Computers & Internet
Tip
My laptop doesnt Hibernate.
Most of the times a laptop would fail to hibernate due to an OS Driver Management Issue.
Even after doing Lot of Homework on setting up the Hibernation settings, if your laptop is not hibernating, Check for the Posibility of having a new device attached to one of the ports or a new application installed.
Usually when a hibernation process starts the Kernal would enforce the App Manager and the HAL to communicate with the backend process and the Driver programs to close down the operation and write back the system state logs to the hiberfil.sys.
The Applications and Driver programs running on a windows system should abide to the WDDM Framework. (Windows Device Driver Model). A device driver which is running on a windows system if not written to follow the WDDM Framework shall refrain from closing the ports and getting to the hibernation status due to which the kernal will not be able to close the programs and return to hibernation mode and this keeps the system running live.
So check for any such new applications running on your Windows system and also check for any Wireless device like (Mouse or Keyboard) which is not Windows Compatable and running on the system.
Hope this solves the issue. (Good Luck).
on Feb 13, 2010 | Computers & Internet
WENT INTO HIBERNATE AND NOW WILL NOT TURN ON
rather than hibernating try to put to sleep mode hibernating will slow down the system.
Jul 02, 2010 | Gateway GT4016 Desktop PC
When turning on the computer sony vaio pcv-rx753
IF YOU DO NOT USE THE HIBERNATION OPTION THEN YOU CAN GO AHEAD AND DISABLE IT
NOTE: HIBERNATION OPTION CONSUMES A LOT OF SPACE ON YOUR COMPUTER.IT MIGHT HAPEEN THE COMPUTER DOES NOT HAVE FREE SPACE SO THAT IS WHY IT IS GOING TO HIBERNATION.
PLEASE FOLLOW THIS LINK AND THEN CHECK WHAT IS YOUR EXACT PROBLEM:http://support.microsoft.com/kb/929658
MY EXPERIENCE:If you happen to use a computer with more than 1GB of RAM coupled with Windows XP SP2, then you will have trouble putting your computer to hibernation. You may get this message, “Insufficient System Resources Exist to Complete the API”. When you experience this problem, the hibernate feature is not available on the computer until you restart the computer. I was facing this problem because my computer has got 2GB of RAM and putting it to hibernation was causing me trouble. Well you need not worry about it any more as Microsoft has issued a patch for this problem
Jun 23, 2010 | Sony VAIO PCV-RX753 PC Desktop
Im using winxpsp3. while shout down time it takes lot of time to shout down. please give suitable solution
you must have installed many a applications on you pc,, and beware,,, do not update your sp, form microdoft web site, it'll slow down your speed,, now you only left with the option is go to control panel,, power option,,, hibernate,,,,, enable hibernate,,,,then go to advace,,, on the option of when i press power button,,, select hibernate,,,, apply,,,, ok.,,,, now whenever you turn off the computer,,, just press power button,, it'll incirese your speed
Jan 08, 2010 | Microsoft Windows XP Professional
Why does my computer's screen turn black and stop working while im using it?
It's most likely a heat related issue. Laptops need to have the fans and air vents blown out regularly. Also, they need GOOD airflow. An under computer cooling fan will add a lot of airflow. You can get them for $15 & up.
Oct 12, 2009 | Computers & Internet
Will not hibernate, high power use in standby. BIOS Setup 1.70 does not offer any power management options. How should I fix?
Brand and model? I'm pretty sure this is not a printer. Do you have XP or Vista on the machine?
Jul 17, 2009 | Office Equipment & Supplies
Dell inspiron 1525 w/ Vista 32 will not hibernate
Hibernate issues are generally an issue with the Video driver. Try the following: Update to the latest list of drivers from support.dell.com BIOS Video Driver see if the issue is resolved. If not, then try editing the startup group of MSCONFIG and see if an item running at startup is causing the issue. (Start, RUN, MSCONFIG, OK to open MSCONFIG)
Jun 09, 2009 | Dell Inspiron 1525 Laptop
Laptop hibernates randomly
go to the control panel and open power option change your setting there
Oct 04, 2008 | Computers & Internet
Slow booting
check your start up files what gets preloaded get software like reg cure it will show what is been loaded on sartup
Nov 16, 2007 | Zerus Intel Desktop Board D815EEA...
Toshiba Satellite C655-S5068 Notebook Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
