Question about Scan Computers LaserJet M4345xs All-In-One Printer
How do I install a fax from a HPJ5780Officejet
We have no manual and are unable to fax, please help.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Scan Computers Master
  • 102,366 Answers
Http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3301296&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Aug 02, 2010
I am unable to send a fax brother intelifax 775 fax manual
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
Fax Reserved
try unpluging the machine and the replug and let the machine reboot. brother tech
Jan 07, 2009 | Brother MFC-8440 All-In-One Laser Printer
Unable to send a fax
You can review the User Gide here. Information on faxing starts on page 12. Hope this helps. Please remember to rate this information.
Nov 11, 2008 | Lexmark X1270 All-In-One InkJet Printer
Unable to receive fax unless Westell modem is disconnected
sounds like you have a modem problem and that should the telephone company's call.
Jan 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
Auto print
push the power button on once:D
should work fine after that
Oct 04, 2007 | Canon FAX-JX200
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Scan Computers LaserJet M4345xs All-In-One Printer Logo
32 people viewed this question
Top Scan Computers Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Scan Computers Office Equipment and Supply Expert? Answer questions, earn points and help others
