Question about Zenith IQB50M90W 50" Rear Projection Television
Zenith inteq iqb50m90w has no sound, hooked up cable box with component cables
I got this tv from my father in law who had it set up with a Bose sound system. Speakers have not been used much on the tv. I tried switching the audio output switch to no avail. I have tried every wiring combo possible. Any help would be greatly appreciated.
    Top Expert:
  • Zenith Master
  • 14,553 Answers
To be honest I do not really understand clearly your issue so I will pose a few questions that might clear things for me up:
1. No sound from internal speakers.
2. Speakers have be checked and are not open, disconnected or switched to external or variable audio out only.
3 A DVD or similar connected to a rear video and audio input has no sound.
4. The set had sound when hooked to the bose system.
Do I understand correctly or did I miss something?
If all the above is correct the set has a audio output problem (old trick is put ear directly to a speaker and see if anything, a buzz, faint sound or nothing at all.)
Posted on Dec 04, 2012
2 Suggested Answers
SOURCE: variable audio out has no output
I turned off the internal speakers in the TV and the external speakers then worked.
Posted on Feb 26, 2008
Snow no connection to cable box
the fact that you are seeing snow tells me that your tv in in the tuner mode .. your cable box is more likely hooked up to the AV input (composit video + 2 sound channels ..3 wires total) .. or it could be hooked up to component inputs (5 wires total) ... you will have to go to the menu of the TV and choose the proper input ... if your cable box is actually connected thru the tuner (coax cable to RF input .. one cable) then you have to select the same channel on the tv as what the cable box is set to .. that is usually chan 2 or 3 ... there is also an svideo input on your tv .. that can take the place of the composit input ..
here is a diagram of the back of your set so you can determine how its hooked up ..
http://www.fixya.com/support/p169436-zenith_p42w46x_42_in_edtv_plasma/manual-6443/page-8
lots of other good information there as well
Oct 03, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Cable Guy messed up Bose 18 sound
Make cable guy get you one.I cant believe he left without fixing it.
Sep 20, 2009 | Bose Lifestyle 18 System
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bose lifestyle v20 sound but no video
The problem turned out to be the TV itself. Somehow all the a/v and component cable inputs on the back of the TV got disabled. After finding then consulting the TV manual online (the TV is about 8 years old), we found there was a way to reset the TV to its original factory settings. Voila, the a/v and component cable inputs were enabled again, and everything worked correctly afterwards.
Sep 26, 2008 | Bose Lifestyle V20 System - black Theater...
Am setting up a bose GSX 3-2-1 home theater
simplist solution, if the TV has an audio output just run that to the Bose system.
what type of TV are you connecting to?
Is the cable box an HD or digital box?
Jun 23, 2008 | Bose Cinemate Digital Home Theater System...
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
"No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Feb 07, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith IQB50M90W 50" Rear Projection Television Logo
64 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
