What does the user interface look like? - Washing Machines
  • 3,051 Answers
Hello there and welcome to fixya
Depending of the type of machine and the model of the machine itt will be different but here isnwhat one looks like from a whirlpool duet
Posted on Dec 04, 2012
What is error f 71?
F71 USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving.
Nov 28, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
Tip
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71: USER INTERFACE HEARTBEAT FAILURE
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
on Nov 05, 2010 | Whirlpool WFW8300SW
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
Had F70 &F71 changed ccu and ui won't power up just beeps
Even after they replacing the CCU and the MCU, I still kept getting the three beeps and the F70 Error... the fix was replacing the front controller boards (where the knobs and buttons are). check your connections also, and that they are in the proper slot.
Oct 31, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
Im gettina an f70 f71 code on my machine what does it means?
F70=CENTRAL CONTROL UNIT HEARTBEAT FAILURE
F71=USER INTERFACE HEARTBEAT FAILURE
Repair Sequence:
user interface is about $195 New;CCU is about $200. Hope this helps!
May 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not turn on flasheing F71
F71 error code USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit. Possible Causes/Procedure 1. Check for continuity of the User Interface harness. 2. Check wire harness connections to the User Interface and the Central Control Unit. 3. Replace User Interface if drum is rotating. 4. Replace Central Control Unit if drum is not moving.
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
Error code f70
F70 Error code means Central Control Unit Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71 error code meansUser Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
In both the above situations the following things are required to be checked and replaced where required:
1. Continuity of the User Interface harness.
2. Wire harness connections to the User Interface and the Central Control Unit.
Oct 04, 2010 | Whirlpool Duet WFW9550 Washer
F-70 f-71 what do they mean
Hi!
F71 error code means User Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 16, 2009 | Whirlpool Washing Machines
Kenmore elite he3t
maybe a false code if so may mean new control bd ..tech sheet is behind bottom panel with all fault codes if not on there code is a glitch in control
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
