I need to replace the user interface but dont now what it looks like.the code saide to change ui if drum is not locked.
I also cleaned the inlet hoses hot and cold.
  • 3,051 Answers
Hello there again and welcome back to fixya
The UI is the user interface it is the controle board that controlls everything this is a $ 200 to 300 part depending on the unit ok let me know if you need troubleshooting advice ok
Best regards mike
Posted on Dec 04, 2012
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
  • 96 Answers
SOURCE: mavt634 cold water comes out the hot water inlet connection
Need to make sure that the water connections are correct - first that the hot water hose and cold water hose have not been interchanged and then if they are correct try interchanging the electrical connections to the water valves.
Posted on Mar 10, 2008
  • 15 Answers
SOURCE: Water filter at inlet hose on LG WM2016CW
Why not try to clean these with a little CLR lime and rust remover and see if that does the trick....
Posted on Sep 06, 2009
willzb_84
  • 17 Answers
SOURCE: I have a GW512. The
Hi dan, in all probability it is your inlet solinoid valve, due to high sediment build up in the main water supply can cause the inner diaphragm of the inlet solinoid valve to clog up and stick. you can pick up a new inlet valve anywhere from $25-$60 depending on the appliance spare parts outlet. If you produce your model number with the name of the machine to the spareparts store they will easily be able assist in your matter, even better supplying the spareparts store with the inlet solinoid from the machine, thumbs up if this helps thanks.
Posted on May 02, 2011
Testimonial: "thanks for your wisdom."
SOURCE: bosch 2460uc washing machine give water tap closed
Water tab goes off all the time, get rid of machine, don't buy Bosch
Posted on Jun 02, 2011
How to clear f99 code model number wfw9750ww01
Maybe this will help, but I'm not sure
F99 - NOT SUPPORTED
User selected on the UI the unsupported Cycle on the CCU. Mismatch of User Interface
and CCU or corrupted EEPROM.
Potential Causes
1. Perform Service Cycle to pair the UI and CCU SW.
2. Replace User Interface.
3. If failure still present, replace also the CCU.
NOTE:
During first power up of new CCU and UI combination, a bootphase (uploading
parameters) will be performed. This upload can be forced also by the Service
Testprogram.
Entry:
1. Plug in the machine
2. Machine switched off.
3. Press any key except power for 3 sec, release for 3 sec.
4. Repeat this procedure 3 times
During the failure history indication the upload will be done
UI-user interface
CCU-central control unit
Dado
Sep 21, 2015 | Whirlpool duet Washing Machines
Ned's to know witch relay to replace wich f8 problem
Hi there! Typically for such an error code, F8 or F80, there is a communication error between the UI (User Interface) and the control board (often the microwave control board). Yes you have a microwave control board in a double wall oven. This will require either the main control board or the UI board being replaced by a professional for safety reasons. I would suggest to contact a professional that partners with your manufacturer. Contact your manufacturer first to see if there are any known issues or a limited warranty for your model.
Mar 30, 2013 | Frigidaire 30 in. Electric Gallery Series...
I have a microwave problem. My KitchenAid Convection/Microwave oven is showing error code "F6 E0" on the display screen. This occured after power lose and restore.
Hi Kent:
F6 E0 means that you are having a Lost Communication Error between the appliance; unfortunately this is the worst error code you can get on this model because there is no way to test for which part is definitely bad. You'll need to uninstall the oven and remove the top panel and the left side panel. make sure the wires are secure going from the interface control board to the program manager board on the left side of the oven. If it checks good, you'll need to make a guess and just replace one of the control boards because one of them is bad and you can't test to see which one is faulty.
Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic mode and verify the error codes. Ensure AM software, UI software and EEPROM CHECKSUM versions appear on the lower text line. If AM software and EEPROM versions do not appear, UI and AM may not be communicating. Verify this for the lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show the AM software version for the lower oven appliance manager, and the microwave UI will show the AM software and EEPROM versions for the microwave appliance manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions, go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between P6-1 of the appliance manager and P2-1 of the user interface board. Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to P2-5(UI). All the measurements made should be less than 5 ohms. If any of these measurements exceeds 5 omhs, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least 1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance manager has already been replaced.
- If both are replaced the problem has been repaired.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 10, 2011 | KitchenAid Washing Machines
Had F70 &F71 changed ccu and ui won't power up just beeps
Even after they replacing the CCU and the MCU, I still kept getting the three beeps and the F70 Error... the fix was replacing the front controller boards (where the knobs and buttons are). check your connections also, and that they are in the proper slot.
Oct 31, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
How do I know which user interface I need for an error code F71? I'm getting an F71 error code. The washer will not start at all. Model WFW9200SQ00 Whirlpool
Hi
F71 is a communication error and is displayed when there is no communication from the User Interface to the Central Control Unit. First check the user interface harness for continuity and then check the wire harness to the user interface and CCU. If the drum rotates then replace the user interface, if the drum is not moving then replace the central control unit (CCU). Hope this helps...please post back for further assistance.
Daniel
Aug 11, 2011 | Whirlpool Washing Machines
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
manager.
EEPROM VERSIONS.
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
1 minute.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
I also get 3 short beeps when I press the power button, and the only button that works is the Controls Lock/Unlock... The machine no longer can be powered up. The F70 an F71 error codes are stored up on...
Hi
Thanks for using FixYa. Error F70 and F71 indicate no communication between the Central control unit and the user interface. To start with you’ll need to check continuity of the user interface harness and also check the wire harness connections. You can also try to rotate the drum, if the drum is rotating the User Interface should be replaced and if it wont move then the Central Control Unit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
F71 problem on washer display
USER INTERFACE HEARTBEAT FAILURE:
If CCU heartbeat failure is displayed, no communication is detected from the UI to the CCU.
Possible Causes/Procedure:
  • Check for continuity of the UI harness ( afro.gif)
Check wire harness connections to the UI and CCU ( afro.gif)
hope this helps...
Oct 25, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3t
maybe a false code if so may mean new control bd ..tech sheet is behind bottom panel with all fault codes if not on there code is a glitch in control
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
