Question about HP Md5880n 58 in. HDTV
Purple line left side down the screen how can i fix it sanyo 46 inch lcd
Johnboy36
  • 77 Answers
SOURCE: Permanent Red Line Down the left side of the screen
This can't be repaired, the LCD panel is a sealed unit. if you can't live with it then you need a new monitor
Posted on Feb 20, 2008
leroyal
  • 2120 Answers
SOURCE: Lines down both the left side of the printouts.
Could be leaking, probably a bad drum cleaning blade. Not accessable. You must replace the whole unit.
Posted on Oct 14, 2008
SOURCE: vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Posted on Jan 23, 2009
  • 25 Answers
SOURCE: One inch dark smudge line from top to bottom on the left side
Bad fuser. Replace it.
Posted on Jul 16, 2009
  • 1288 Answers
SOURCE: my hp dv4 have vertical
If you are lucky, this may be down to a loose vga cable connection on the back of the screen, or at the motherboard.
First eliminate the possibility that t may be graphics chip related by seeing if the laptop will work on an external monitor without the banding you describe. If it will, you will need to remove the laptop screen and see if the connection there is tight. Check also at the motherboard end (remove keyboard and switch panel)
If it is tight, then suspect that the screen is beginning to fail, look for a replacement.
If the monitor shows a similar pattern, the issue is with the graphics chip ( common problem with HP laptops)
Posted on Jun 19, 2011
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
How do I fix a A black screen on the left side of
Hello; I do a lot of Sanyo repairs and have seen this problem several times. The left side may be black always or sometimes. In either case the LCD panel is bad. the part from Sanyo was last $1000.00. There seems to be some refirbs or knockoffs for $400. Time for a new set. John
Jul 08, 2011 | Sanyo DP46849 46 in. HDTV
We have a Sanyo 46" 1080P lcd tv that has been going black on the left side for about 2 months now ,it's like a black square on the left side , can you tell me what this is and what the cost would be to...
We've had the Sanyo 1080p Flat screen TV for about a year and a half and the right side of the TV is black when we turn it on and after about 45 minutes in brightens. Sometimes it still has lines flickering throught he uper right.
Solution?
Oct 05, 2010 | Sanyo Televison & Video
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Apr 22, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Apr 03, 2009 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Sanyo Bravo
check if its on all the video sources. check it on dvd if its there then contact the customer care
Jan 07, 2009 | Sanyo DP32746 32 in. LCD Television
HP Md5880n 58 in. HDTV Logo
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
