Question about Hitachi 55HDS69 55 in. Plasma Television
It doesn't want to turn on
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If you have the Plasma model listed here it is 95% boards--you can check the fuse but that is about all the average person can do, presuming they can safely get the set apart----Unless you have a good background in this kind of repair I would suggest having a shop look at the set and get an estimate.
Posted on Dec 04, 2012
Diagrams ignition systems
Hi Anonymous, for a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
May 18, 2013 | Harley Davidson FLSTC - FLSTCI Heritage...
What is wrong when you turn the key to start and the radio and all the instruments turn on but the starter doesn't click and the engine doesn't turn on even after trying to jump start it
Dead battery
Dangerous practice to try & jump a dead battery
The battery cables could be loose at either end or corroded internally
Most likely the battery is worn out, if original to car
since it was new, or the starter solenoid is worn
You do not want to jump any vehicle made after the
year 2000 or your asking for possible problems with
todays electronics.
You need a good battery that has been tested & fully
charged, then only jump with a jump pack,not another car
Jan 21, 2013 | 2008 Buick Lucerne
Fan light turns on but doesn't turn off with remote also fan doesn't go on with remote
Make shure your batteries are good in the remote. Also some remotes have little dip switchers inside the battery cover that are either on or off. They must be in the same position as the dip switches on the receiver in the top canopy of the ceiling fan or the remote & receiver won't talk to each other. Apart from that you will probably need to replace the remote control & receiver unit.
Dec 12, 2012 | Hampton Bay 52 In.Carriage House II in...
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
I got my KM60 in Singapore where they use 240V. I moved back to the states and now when I turn it on the amp buzzes for a few seconds and then it has a faint static while it is on. This static...
The only change you need to make for the 120 operation should be to change the fuse to a 2 amp fuse. Faint static is typical of the electronic noise of amps... as long as it it is faint. The power supply will act differently on 120 than 240... probably takes a brief more time to get the system stable, hence the initial buzzing. As long as it performs don't worry about it.
Aug 11, 2011 | Hartke KM60 1x10 Keyboard Amplifier
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Jun 20, 2011 | 2000 Mitsubishi Diamante
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 | Vacuums
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Hitachi 55HDS69 55 in. Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
