Question about Dryers
How can I get the front off my whirlpool model# wed5600sqo to change the switch on the door
2 Suggested Answers
SOURCE: door wire
take out 2 screws near the lint filter. open the front with screwdriver from the sides -carefully. then replace the wires.
Posted on Dec 05, 2008
Whirlpool LHW0050PQ4 Front load stackable door switch eratic
Go to whirlpool.com and download manual. download from owner icon
Dec 11, 2011 | Whirlpool Washing Machines
.Whirlpool electric dryer will not work.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is the door switch.
Jan 10, 2011 | Whirlpool WED5200T Electric Dryer
Wont start... the power comes on but when you push the start button it just beeps like the door is open. can you send me a diagram of the door switch and how to change it
IN order to change the door switch, you must remove the outer door spring that attaches the gasket to the front panel. Of course, disconnect the plug first. There are 2 screws that attach the switch to the front panel, if you remove them, it releases the switch and to access the switch, reach inside between the front panel and remove the 3 quick disconnects and the door switch is then removeable... Use caution when reinstalling the door seal and spring in order to avoid leaks. Good luck!!
Nov 20, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Can I change the side the door opens?
Unfortunately you cannot reverse the doors on this model. There have only been two front load washers that I know of that had reversible doors, the maytag neptune and amana front loaders. Your matching dryer for this model, I believe has a reversible door, but you'll have to purchase a kit to do it. IF needed maybe you can switch the dryer and washer locations to make them more accessible?
Sorry, and good luck to you!
Jul 03, 2010 | Whirlpool GHW9100L Front Load Washer
What does F5 mean?
On Whirlpool ovens F5 indicates a failure in the door switch or door latch switch, this is typically right up front in the center just above the door. On some models (not many) the switch is in the back and there is a rod connecting to the front.
May 09, 2010 | Whirlpool Ovens
Light not going on when the door is shut so not starting make whirlpool
most likley to be the door switches sticking up,,, best to change them and put in new ones there only small mickrow switches
Oct 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my whirlpool duet washer won't lock
Sounds like door switch is bad. Look at inside front panel of door, get model number, search on internet for "error codes" with that model number. It should show "DL" door lock defective, not secured, failure. One sure way (in most cases) is to push in on door and hold it firmly closed,it is works,bad door switch. To replace, order new switch, take the whole front panel (front assembly including door) off, switch on back side of panel. DO NOT TAKE DOOR HINGE LOOSE. Replace switch. By the way, before taking apart, UNPLUG FROM WALL.
Sep 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Old avocado green Whirlpool Dryer, door switch?
dryer gets hot 4 awhile then gets cold
Aug 16, 2009 | Whirlpool Dryers
Whirlpool front load washing machine door lock problem.
Get me the model # and i will find the part number for the Door lock mechanism and the ccu. Replace door lock mech first.
Nov 15, 2008 | Whirlpool Washing Machines
Dryers Logo
19 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
