Question about Sylvania LC370SS9 LCD TV
I have a Sylvania lc370ss9 hdtv. When I turn the power on the set remains black, the power indicator flashes green and the power button will not shut it off.
When I turn the power on, the set remains black, the power indicator flashes green and the power button will not shut it off.
  • 1 more comment
  • Steve Dec 04, 2012
    Thank you SD Tech. I feel pretty confident troubleshooting if you'd like to direct me to what to look at?
  • SD Tech
    SD Tech Dec 04, 2012
    first place to look is the power board for any signs of damage or puffed up filter caps, the first hurdle is getting the cover off safely---usually have to lay set face down supporting the entire frame around the screen, one wrong move or downward pressure in that position and the display itself can be destroyed===end of the set/ here are some pictures of what bad caps look like, range from very mild to severe.
    I have the cover off and I've searched thoroughly for bulging caps as well as other signs of heat damage and no visual indicators are present.
    Top Expert:
  • Sylvania Master
  • 14,553 Answers
The set has failed to come from standby to on fully---could be the power board but if it will not power off usually it is elsewhere.
Time to have a qualified shop take a look a get a estimate.
Posted on Dec 04, 2012
Testimonial: "Thank you SD Tech. I feel pretty confident troubleshooting if you'd like to direct me as to what to look at?"
  • 27 Answers
SOURCE: Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Posted on Apr 10, 2010
SOURCE: WHAT IS DIRECT TV CODE FOR SYLVANIA LC370SS9
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
Posted on Jun 07, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Sylvania LC370SS9
Your unit being stuck in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in standby mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
I do not think the defective power board needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Jan 01, 2011
SOURCE: my Sylvania TV LC320Sl1 will
lori2scott...did you ever solve your problem? Mine is now doing he same thing and I dont know what to do. Thx pwest17
Posted on Feb 12, 2011
  • 4 Answers
SOURCE: How do you Wall mount
If you have a wall mount kit, it is fairly simple. You just find the place that you want the tv to go and find a nearby stud to install the mount. After that you will want a second person to help with either holding the tv up or screwing in the tv to the mount. There are four screw holes in the back of the tv to screw through the wall mount plate into the back of the tv. Check to make sure it is stable, then you have successfully installed the tv to your wall
Posted on Jun 17, 2011
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Set turns on displays logo then shuts down
This is an indication of some board failure inside and must be investigated only by a qualified service technician.
Aug 19, 2012 | Televison & Video
Black screen at startup
It sounds like the graphics card or on board graphics is causing the issue, as the external monitor is not working either. Hopefully its a graphics card which can be replaced easily, or there is an expansion slot for a graphics card to be added.
One thing you could try is resetting the CMOS by removing the battery from the motherboard and leaving for ten minutes. Replace the battery and try booting.
Mar 14, 2012 | ASUS Computers & Internet
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
TV goes black, won't power off
If the power indicator remains on (or LED remains green) when the unit goes dead, you will need to replace the main board to resolve.
Dec 22, 2008 | Vizio L32 32 in. LCD HDTV
Sylvania LC370SS9 LCD TV Logo
523 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
