Question about Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer
Dryer wont heat up - Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer
  • guybball Mar 28, 2009
    The dryer works but it makes noise and does not heat up
Do you get at this heater from the front or the back? The diagram shows screws in both directions.
Thanks
Posted on Mar 05, 2009
Sounds Like your Heating Element went out
Posted on Jan 12, 2009
The dryer wont heat up its gas what do I do
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 17, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer wont heat just spin
heatman101
Nov 29, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Dryer wont dry, no heat
heatman101
Oct 16, 2010 | Smeg WDF16BAX Front Load Washer / Dryer
My dryer wont heat up, the drum spins but there is not heat! any help?!
heatman101
Sep 04, 2010 | GE Spacemaker Washer and Dryer Electric...
My LG tromm dryer wont heat and i don't know how ignite the pilot
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
Dryer wont heat up
my dryer wont heat up the element tested good
Sep 28, 2009 | Whirlpool LTE5243D Top Load Stacked...
Dryer wont heat up and now wont turn on at all
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Apr 06, 2009 | Whirlpool LER4634PT Electric Dryer BISCUIT...
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer Logo
126 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
