Question about Kenmore HE5 Electric Dryer
I am looking for the part number for a Kenmore HE5 Electric dryer Belt Switch Pulley (Belt Pulley Tensioner) and its bearing kit
My HE5 dryer (the service booklet in it identifies this as piece no W10110639) was squealing real loud. Thanks to this site I learned it was likely a roller. When I got it apart I found it was actually the belt tension pulley whose bearing had ground right down. Does anyone know what the part numbers I'm looking for are or where to find them? Thanks all!
dididsaythat
  • 291 Answers
SOURCE: kenmore dryer
The pully fits in some groves at the bottom of the motor shaft , the pic should help 9b7b31e.gif
Posted on Oct 14, 2007
SOURCE: Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Posted on Jun 12, 2008
  • 188 Answers
SOURCE: kENMORE SERIES 80 DRYER..The Tensioner use it or not and how?
To fit the new belt, you will need the idler pulley (tensioner)...
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side. Once the belt is pulled through the idler pulley, pull it around the motor pulley (this should force the idler pulley to "open up" and add tension).
If you still need help, I will try to provide you with a diagram shortly.
Posted on Mar 02, 2009
jsrock516
  • 5911 Answers
SOURCE: pulley came off dont know how it goes back on
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, there will be a link for "Dryer Belt Diagrams under the "Special Features" section. Scroll down to Kenmore. Since you didn't post a model number, you will have to look at diagrams H, B, or K. If you are confused, please let me know. I hope this helps you.
Posted on Apr 07, 2009
Controlfrk
  • 304 Answers
SOURCE: kenmore Belt Tensioner
At the link you will find the belt configuration for your machine and others.
Dryer belt configuration
Posted on Oct 05, 2009
Washer not working, dryer is
You should really provide a LOT more information than that. Such as what specifically is not "working".
If that panel is off, make sure it's unplugged. Be careful and good luck.
Dec 03, 2017 | Kenmore 24" Laundry Center w/ Electric...
The dryer is working but is very noisy, I checked the legs on the bottom already and they seem to be fine.
Check for worn drum bearings or rollers, and check the belt tensioner pulley for worn bearings (don't forget to look at the arm pivot bearing).
Jan 23, 2011 | Kenmore 63032 Electric Dryer
The dryer is making a terrible noise, and the drum has stop turning. How many belts are required? when lifting the top and checking the belt should there be any play between the belt and the drum?
Only one belt is used ,their should be no slack between belt and drum.If you can lift up the belt and it dosent snap back tou have a tensioner problem , that could also be part of your noise concern
good luck
Aug 08, 2010 | Magic Chef CYE3005AYW Electric Dryer
The dryer started a squealing and slamming noise yesterday. Is this the belt? Is it an easy and inexpensive fix?
$30 repair for a DIY
Top and Front panels are removed
Replace the belt & tensioner pulley which SEARS sells in a KIT
Jun 15, 2010 | Kenmore 62602 Electric Dryer
Dryer makes loud grinding noise when you cut it on
The dryers drum runs off a belt as you may know to spin it around to dry clothes. This belt is attached to a belt tensioner also to keep the belt snug. This tensioner has a roller with a bearing in the middle of it. Most bearings are made of brass and wear out causing it to grind
I would replace the belt & tensioner pulley as a unit. Sears will have these two parts selling together as a kit. Go online to view with your make and model number to see
May 31, 2010 | Whirlpool LER4634J Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Cant figure out how the belt tensoner works to hold the belt tight i have a kenmore 70 series electric dryer
There are 2 slots underneath the motor pulley.
The flat part of the tensioner goues in these slots.
The roller wheel will then be on your left.
With the belt around the drum, run the belt under the wheel and through the tensioner, then over the motor pulley.
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Kenmore dryer
It is very much easier to replace the belt from the front, than the back, the cabinet disassembles from the front, and the mechanism remians attached to the rear plate and cabinet floor.
  • pull lint filter out
  • remove 2 screws from under lint filter
  • with putty knife or other blunt blade, release clips at front corners of cabinet top
  • tilt up cabinet top
  • remove 1screw 1/3 way down each side of front of cabinet.
  • lift off cabinet front
  • drum, motor, tensioner, are all exposed
  • lift drum out forward
  • check rollers, drum felts, nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage and you dont want to do it again next month)
  • reinstall tensioner in slots in cabinet floor, reinstall tensioner spring between tensioner and cabinet floor
    (Once the cabinet is open the tensioner mounts are easily visible)
  • loop belt around drum at the wear marks of the prior belt
  • reinstall drum on unworn bearing rollers etc
  • loop belt around motor pulley
  • pull tensioner hard against spring to end of travel
  • loop belt around tensioner
  • relax tensioner
  • spin drum by hand to ensure belt isnt going to jump off
reinstall cabinet in reverse order
~15 MINUTES, but I do 3-4 per day
Oct 07, 2008 | Kenmore 62602 Electric Dryer
Hot point dryer
the drum has dropped
the drum is suspended on felt pads to seal the drum edges, nylon guides at the front, and rubber tyred thrust rollers to withstand the torque of the motor and belt at the rear.
the usual cause is the rollers have failed, common fault, easy fix, cheap too
good rollers look like this
1ac2db2.jpg worn rollers like this
try not to run the dryer till the rollers are replaced, the extra strain will break the belt,
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
  1. drum motor felts and bearings are now accessible.
  2. pull tensioner fully agains spring
  3. remove belt from motor pulley
  4. lift drum and withdraw fully forwards
  5. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear
reassemble.
  1. loop belt loosely around drum at wear marks from prior installation
  2. reinsert drum onto rollers bearings slides felts as installed.
  3. loop belt around motor pulley
  4. pull tensioner pulley against spring to end of its travel
  5. loop belt around tensioner pulley
  6. relax tensioner pulley to tighten belt
  7. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Jun 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore HE5 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
