How do you reset a Estey Legends Organ
The power light and the other lights work plus foot pedels work, but the keys and the rest doesn't work
SOURCE: Legend By ESTEY organ
This happens when organ sits in none use state for long periods. My Legend was in storage from 2001 to 2004 and I had to call the Estey company to get "reset" instructions. I wrote them down as...."TO RESET---PRESS TRUMPET/TROMBONE BUTTON---TURN OFF---TURN ON---WAIT FOR "HARDWARE RESET" DISPLAY.
Hope this works for you.
Marquita
Posted on May 19, 2009
Macmarkus
  • 2605 Answers
SOURCE: Re: Model # 665-17039401. Clean light
Hello, Welcome to FixYa.
Based on your description, "clean light stays on" this is actually an error code as you may or may not know associated with the heating process. What typically happens is poor water circulation preventing the water from heating properly.
To resolve this, I'd start with the following...the wash pump area. You`ll need to follow these steps to clean it.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Once these actions have been performed you'll need to clear the error code. to do so is as follows.
Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear. Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 10, 2011
johnjnail
  • 1702 Answers
SOURCE: No dash lights, power locks don't work, fuel
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Posted on Jun 20, 2011
SOURCE: model:olivetti pr2 plus passbook printer On
head cable be not fixed properly or may be damaged secondly ps card may be not good
Posted on Jul 26, 2011
  • 80 Answers
SOURCE: i cleaned my laptop's keyboard
change your key board
Posted on Aug 16, 2011
Legend Organ by Estey
as for fixing it, to find a tech in your area go to
Electronic Repair Services for the Entire Music Industry MITA International
As far as value, it's very hard to say. The current market for anything but tonewheel hammonds is almost nill in my market (north florida). Your market is hopefully better.
May 10, 2013 | Music
My 2000 lincoln ls doesn't crank or click when trying to start it, it does nothing? all the lights work, radio, signals and horn, I checked the fuel relay and the starter relay and the ignition fu
Sounds like an Ignition Module or similar device. Does it have an alarm? Turn the key to ON - not start - and put into Drive and then back into Park. It may be the shifter isn't fully engaged. Also, w/your FOOT ON THE BRAKE shift to Neutral and try to start it.
GL,
Td
Oct 01, 2012 | 2000 Lincoln LS
CL trouble light flashing
If you reset the unit from the household circuit breaker and it doesn't change, then contact a professional to have the main control board repaired.
Aug 19, 2012 | Electrolux Frigidaire Professional Series...
Brake and tail lights out
Im not sure if i understand exactly what you mean .You are saying that the brake lights and the tail lights don't work. But the first thing i would check would be the brake switch. Witch is located on the top of the brake pedel . Its like a light switch in your house its on or off and also most of the time has an ajustment that you could turn a nut if its not touching between the master cylinder rod and the pedel that you are pushing with your foot when you hit the brakes. If the switch is bad witch isn't uncommon its an inexpensive part about 10 dollars . And you need to remove a clip that holds a pin that slides through the upper part of the brake pedel then the switch will come out and is easly replaced ; But test it first like i said its like a light switch its on or off theres no half way and its likely your problem
Apr 08, 2012 | 1997 Pontiac Trans Sport
When I turn on my xk1, I get no sound, no response from any buttons, keys, drawbars or knobs. I have tried the factory reset and it doesn't work either. What else can I do before I return it to the...
Take it to the store and have them test it... don't be surprised if there is a simple thing that has been overlooked. If it doesn't worked there, it needs to go in for servicing so that is the logical course to follow anyway.
Aug 06, 2011 | Hammond XK1 Pro Drawbar Organ
The pedal keys doesn't work, no sound coming out of the upper notes of the pedel keys.
We can only guess at what type, model, and brand of instrument you have.
This is probably some type of organ... however there are many types.
IF the pedals are part of the main body of the organ, I would suspect a broken wire.
If it is a console organ, often the pedals have tabs that actuate switches. Often people place thess on a rug which CAN block the pedal from moving far enough.
Another thing is that SOME voices that can be used by the pedals on some organs do NOT span all the pedals because the instrument being emulated won't go that high in pitch.
Feb 08, 2010 | Music
Estey chord organ giving off sharp metallic smell
The organ is basically a harmonica gated by keys. It has reeds and a fan.
I would open it up and clean everything. It is possible a mouse has gotten in there and they stink including their messes for quite a while.
You might need to lube the fan.
Aug 26, 2009 | Music
Marquita
Jan 05, 2008 | Audio Players & Recorders
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
