Question about Samsung HL-S4266W 42" HDTV
My dlp hl-s4266w had developed a 10 " wide vertical darker area than the rest of the sceen
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Usually this will be on top or either side and the problem is the optical light engine is damaged from heat----seen about a dozen.
Posted on Dec 04, 2012
SOURCE: have white dots on screen. model HL-S4266W
it seems like you might have an issue with your dmd board. Go to the tv menu and if the dots also show there, the issue is with the dmd board, but if they don't, it's with the video board
Posted on Aug 03, 2009
  • 184 Answers
SOURCE: Samsung DLP HL-S4266W White dot problem
Its the DLP IC chip itself that is bad. The DMD board is where the chip resides but if you order a board, it will come without the chip. Its not cheap and the replacement is tricky because the DMD board must be removed and then an alignment of picture centering will be necessary.
michtech
Posted on Feb 14, 2009
  • 304 Answers
SOURCE: samsung dlp tv hl-s4266w has white spots on it?
Are they spots or dots? If they are spots then the optics are contaminates. If they are dots either white or black then you have a bad DMD chip. The cost of repair depends on who you hire to repair the set or if you do it yourself it depands who you purcahse the part from.
Posted on Jul 17, 2009
  • 280 Answers
SOURCE: Numerous white spots on Smasung DLP TV
dmd chip Is bad
Posted on Sep 21, 2009
SAMUEL011
  • 39 Answers
SOURCE: samsung HL-S5687W dlp tv, the picture is darker
Hi
Well for what you describe it sounds like the symptoms of a worn out lamp giving you the last kicks,basically the the lamps are design to go for 6,000 to 8,000 lamp hours if they're Phillips and a generic lamp could give you 3500 to 4500 lamp hours so with this in mind you could search for a new lamp at Discount-merchant.com or you can go to Ebay also you can go to www.fixyourdlp.com for more troubelshooting
Please rate this if it was helpful.as I do this for free.
Regards
Posted on Jan 05, 2010
Testimonial: "Very prompt solution to my problem, thank you. "
My Samsung DLP TV S4266W has snow all over the screen. I've been told I need a new motherboard. Is that true? How much would that cost? Can I buy and install it myself?
Had this problem it is cosd by a befect in a chip call compy and thay will repace for free........no matter how old your set is take care
Jul 18, 2012 | Samsung HL-S4266W 42" HDTV
Samsung HL-S4266W 42 in. TV has a bad DLP module. Specifically, an increasing number of bright white dots are appearing on the screen. What's the part number for a replacement module, and where can I buy...
The part # all depends on which version of the set that you have. Take a gander round the side of your side. Right side, if memory serves. You should see a sticker with 3 lines. One for model #, one for serial and one for version.
On the off chance you don't see one, check around the left side of the screen and take note of the lamp code. Your version will probably be a PB01 or PB02.
Depending on the version, the part # changes. Either way, you're looking at about $200.00 for a DLP chip. That's just the chip mind you, not the DMD PCB that drives it, or the rest of the light engine that helps process that information. I have had, during the course of my career, replaced a DLP chip to address white spots on the screen and found that insufficient voltage from the power supply cause the issue in the first place, or that the light engine itself was a contributing factor.
If you were to replace the light engine itself, you would replace all three components here and guarantee yourself a solid repair. You would hit the LE, the DLP and DMD all at once by doing a light engine. Granted, the cost is substantially more, but it might be easier in the long run to swallow $600.00 for a completed set than to swallow $200.00 for a DLP chip that didn't fix the issue and now can't be returned. Plus, a light engine will literally take you 30 minutes to put in and be done. Maybe even less.
PS - Don't touch the surface of that chip. And when you remove the DMD, pull out the old DLP chip and insert the new one....you're going to have to have help. Someone is going to need to watch the screen while you manipulate the DMD--set on and running--to align it back to the aperture. Have fun.
Part #s: Version PB01 :
4719-001968
Version PB02:
4719-001981
Try partstore.com to secure parts.
Jan 22, 2010 | Samsung HL-S4266W 42" HDTV
above information is a bit extreme - most likely culprit is dirt/dust on reflecting mirror.....
Aug 27, 2009 | Samsung HL-S4266W 42" HDTV
Samsung dlp tv hl-s4266w has white spots on it? How much to fix?
Jul 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Dark transperant vertical line, left side of screen
Your light tunnel is bad. This requires partial disassembly of the light engine. Suggest contacting a tech
Dec 30, 2008 | Samsung HL-R4264W 42" DLP HDTV
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
DLP HL-R5067W RESOLUTION
Please provide all part info for verification.....Your model is
HL-R5067W.......Engine # = ? , DMD # = ?.....Possible wrong part installed or bad new parts............T.
Dec 21, 2007 | Samsung DLP HL-P5663W 56" TV
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-S4266W 42" HDTV Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
