Question about pdf995 PdfEdit995
Failed to combine files
Nothing happen after combined few pdf files. No error pop-up when perform it only just no file created after combined..
How do i scan multiple pages in pdf
You can only do that if your printer has a feeder. If it only has a cover and a gloss top where you place 1 sheet at a time, you can only do one at a time.
Aug 27, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
My Canon HF M32 divides my recordings into short segments 1.90GB
It is to do with the limitations of the file format in which it is creating the video. You may be able to change the file format settings in your settings menu to get it to create larger files.
Mar 07, 2012 | Canon VIXIA HF M32 AVC AVCHD Camcorder
Why don't my memory card work
Okay... I went looking online because I had the same problem. I couldn't find anything that was solving my problem. Then I stumbled onto a solution on my own. We have Adobe and I noticed that when I right clicked the drive that came up as my SD card, it gave me some options. That option was "Combine supported files in Acrobat..." So I chose this and a box called "Combine Files" appeared and in the box, low and behold, there were all of my pictures, all 403 of them. I then clicked on "Add Folders" in the upper left drop down, created a folder, and changed it back to "Add Files." Then I clicked on "Combine Files" and the program sent all of the photos into a single pdf file. I then went into the pdf file's File Menu>Export>Image>JPEG>Save As. It then shot all 403 pics out as jpegs. It worked!
Feb 27, 2012 | LG Cell Phones
When scanning to a PDF file for multiple pages from the glass, the file won't process and create. I have tried a RIP and clean re-installation of the software but it doesn't make a difference.
Make sure that the Lexmark OCR scan software is installed on your computer. The software aids in creating PDF files and combining multiple-page documents into one file.The software is only available on the installation disc that came with your printer. If you don't have the install disc, please contact Lexmark Technical Support Center for assistance.
Oct 18, 2011 | Lexmark X7170 All-In-One InkJet Printer
How do I scan a multi-page document into one pdf file? Every time I try, the machine creates a separate pdf for each page.
From the University of Texas. This document shows how to combine PDF files using Word or Word Perfect.
Combining Multiple PDF Files Into One These instructions assume you chose to label the first of your multiple PDF files "etd.pdf" as suggested in "Creating PDF Files in Word or Wordperfect for Windows".
  1. Open your "etd.pdf" file in Adobe Acrobat.
  2. Select Insert Pages from within the Document menu.
    [view step 2 illustration]
  3. A Select File To Insert popup box will appear. Highlight the file you wish to append to etd.pdf and then select the Select button. (this process will be easiest if you work your way from front to back through the dissertation, appending successive sections to the first file, "etd.pdf")
    [view step 3 illustration]
  4. An Insert popup box will appear. If you are following the suggestion under Step 3, select the After option under Location. Under Page determine exactly where you wish the selected file to be inserted. If you are assembling the dissertation section by section, you will want the file to be inserted after the last page of the current section. In this case, select Last. Select OK to complete this step.
    [view step 4 illustration]
  5. Check the updated "etd.pdf" file within Exchange to make sure this is proceeding in the order you want.
  6. Continue to add subsequent files in the same way.
  7. When you are finished, exit Exchange and save the file under its original name, "etd.pdf".
Hope this helps. I saw nothing in the printer's manual about doing this.
Also Adobe Acrobat will do it also.
Good Luck
Feb 18, 2010 | HP LaserJet 3330 All-In-One Printer
Hello! I have lost my PDF file password, I wonder how I can get it back
PDF Password Remover is an amazing and professional software to remove the use/open password and restrictions (owner password) on printing, editing and copying from your PDF files.
Feb 02, 2010 | Adobe Computers & Internet
I need to combine Word documents and Excel files into one pdf A-4 size document. The Word documents come out A-4, but the Excel always comes out as letter size??
First you will need to create separate .pdf files then you can combine files with Adobe Acrobat through command Document/Insert Pages.
Oct 16, 2009 | Computers & Internet
Acrobat 7 Pro - combining multiple pdf to single pdf errors
https://acrobat.adobe.com/in/en/acrobat/how-to/merge-combine-pdf-files-online.html
Mar 16, 2017 | Adobe Acrobat 7.0 Professional
Using the print screen button
When you use the Alt Print Screen button then you need to place it onto a word document in order to print it. Open up word and select to paste the frame into your word document and then print it out.
Jul 23, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Computers & Internet Logo
Top pdf995 Computers & Internet Experts
David Payne
David Payne
Are you a pdf995 Computer and Internet Expert? Answer questions, earn points and help others
