Question about Dryers
I have a GE DHDVH52EF0WW dryer that sounds like it has a load of tennis balls in it when it is running.
I have installed a rear bearing kit (bearing was bad), white and green glides (showed some wear) and belt (precautionary). The noise is still present. Any troubleshooting tips/guidance would be appreciated. Thanks, Karl
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
  • 686 Answers
SOURCE: scratching noise coming from dryer
yes the felt is cushion and it sounds like it might be the blower fan sometimes they get off balance or just simply out off wack and the blades will rub on the housing
Posted on Feb 18, 2009
MNTECH
  • 1543 Answers
SOURCE: DRUM BEARING REPLACEMENT KIT Frigidaire GLER341AS2 Dryer
Hi. I don't work on many Frigidaire's, but that pesky ball bearing does not go into any of those grooves. It goes in the very back center of the cradle, sandwiched between the ball and a metal strip on the back side of the cradle. (It is suppose to drain off static electricity from the drum. If it gets lost, it's not a major loss) As for lube, just put a gob of the stuff that comes with the kit in the bottom of the cradle before reinstalling drum.
Posted on Feb 22, 2009
erickg
  • 116 Answers
SOURCE: Fisher&Paykel dryer, ball bearings in the dryer!!
have a service tech replace bearing or do it yourself.
Posted on Jun 03, 2009
  • 65 Answers
SOURCE: Dryer has thumping noise.
Yes that is what most likely is the problem to begin with. The drum usually never goes out of round . Replace bearing best choice
Posted on Aug 28, 2009
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
My king-sized sheets (only thing in load) are getting tangled in a ball in the dryer and not getting dry.
This is pretty common with lighter fabrics and is easily remedied. Put several new tennis balls in with the sheets to keep them from balling up. There are commercial products that do the same thing, but tennis balls are much less expensive.
Kelly
Mar 26, 2011 | Whirlpool Dryers
Dryer repair
The ball gets bolted to the drum first. Then the white bearing gets installed on the back of the dryer. Then It all goes back together when you install the drum into the dryer.
May 04, 2010 | Frigidaire GLER341A Electric Dryer
My dryer, after it heats up, makes a sound like the bearings might be going out. Is this a common problem? Or could it be something else?
it sounds like the roller on the belt tensioner is basd the bearing get hot and expand locking up the bearing causing a noisey sound. if left alone it will cause a banging noise later on. Sears sells the roller and belt in a kit form for most makes of dryers
Apr 20, 2010 | Dryers
GE electric dryer (model #: DRSR483ED2WW) sounds like grinding metal when dryer starts/runs
you need to replace the rear drum bearing by removing the front panel lower screws and then remove the top cover and lean back and secure so as not to break wires to control panel,then remove drum belt,lift out drum and replace with bearing kit
Feb 01, 2010 | Dryers
Dryer makes a squeaking noise when running. I know it's coming form where the drum connects to the back of the dryer
rear bearing kit part number WE25X10001.the drum rides on the rear bearing and that's what is worn out on your dryer
Dec 12, 2009 | GE DSXH43EAWW Electric Dryer
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to install rear bearing on Frigidaire model fex831cso dryer
Not sure you are up to the job as everything has to come out from the front door panel all the way to the back of the machine.
If you are up to it there is a ball like a trailer hitch on the back of the drum that rides in a plastic saddle screwed to the back of the machine, both have to be replaced. MAKE SURE MACHINE IS UNPLUGGED
The kit was about 30 dollars last time I did it and comes with everything you will need. Don't try to reuse the three screws that hold the ball onto the rear of the drum or you will find out what aggravation is.
Also don't leave out the little ball bearing, it has a purpose.
Good luck
Quentin
Sep 12, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
