Question about Samsung LN52A850 52 in. LCD HDTV
Change picture size to normal on Sanyo DB26648 TV without a Sanyo remote
How can I changed the picture size on my Sanyo DP26648 LCD TV to normal WITHOUT using the Sanyo remote? I do not have the remote for this particular TV. I want to make the HD channels appear normal sized. Thank you.
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
SOURCE: my samsung ws28a116d remote will only adjust the
To reset the remote so that it works properly again, take the batterys out of the remote, then press and hold the power battery for at least 30 seconds to drain out any power left in the hadnset , then replace battterys and it should work again. We had this fault and this solution worked for us
Posted on Sep 26, 2009
  • 16 Answers
SOURCE: Tv has no picture
I have the same issue. I am going to replace the main board and then see what happens. the part number for the board is BN94-00629F if you want to try and find one.
Posted on Mar 20, 2010
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
Posted on Mar 17, 2011
How to access the menu on sanyo dp26648 without remote
You can't without the remote. to buy one go here www.remotes.com or try eBay.
Nov 29, 2016 | Sanyo DP26648 LCD TV
2008 sanyo lcd tv DP26648 power turns on but no picture or sound
likely a mainboard or power supply capacitor issue.
if you have the soldering skills fix it, otherwise time to replace the TV.
If you can de-solder and solder in new capacitors make sure you are using high quality capacitors be very causious of capacitors purchased from auction sites.
Apr 30, 2014 | Sanyo DP26648-R 26 in. LCD TV
I last the tv remote model dp26648 i want remote
Setup codes to check with Sanyo brands are 004/ 013. If you wish to get more details about four digit and five digit codes, check this link. There is setup code list to many brands of remote controls. Just see and check which brand has setup code to Sanyo. It will make you remote selection easy. There is an other link. Check this too.
Feb 20, 2013 | Sanyo DP26648-R 26 in. LCD TV
2008 Sanyo DP26648 has a black screen but has sound
Check its T'Con board. This is a common fault to all type of LCD TVs
Apr 02, 2012 | Sanyo DP26648-R 26 in. LCD TV
I have a sanyo 26" hd tv remote was broken i cant get a universal remote 2 work sleep help
Try website like Remotes.com to buy an original remote.Not all universal remote,will function as a original.
Aug 12, 2010 | Sanyo DP26648-R 26 in. LCD TV
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
Feb 28, 2010 | Toshiba 37WLT58 37 in. LCD TV
Remote control code for Sanyo DP26648
remote is worn out cannot change volume, channel , check info etc most buttons have stopped functioning I need code to set up universal remote need it now.
Apr 12, 2009 | Sanyo DP26648-R 26 in. LCD TV
Samsung LN52A850 52 in. LCD HDTV Logo
105 people viewed this question
Henry  Thomas
Henry Thomas
