Sony CDP-C505 door stuck open
The slider mechanism, depending on the age of the unit and the
manufacturer, consists of the small chrome rail, a drive motor, a small
gear assembly, and (in some units) a small belt that drives the slider
unit via the motor. This small belt causes all sorts of problems. If
the belt is broken or slipping, it can cause skipping, dropouts, or
simply no start up at all. Also, if the belt breaks in the middle of
the disc, the drive mechanism gets hair or dirt wrapped up into the
gears, or the pick-up assembly doesn’t return to the start position
(called home), the unit will (99% of the time) refuse to release the
disc, causing it to become stuck inside the unit. There’s a little
micro or leaf type switch located at home position that sometimes gets
dirty or breaks and, causing this problem also.
If the disc starts
to spin slowly and doesn’t come up to speed, the spindle motor that’s
attached to the turntable platter is a common problem. There could also
be a problem with the spindle motor driver controller IC or the power
supply regulator that supplies voltage to the driver IC. If the disc
starts to spin and then spins really fast, or stops and starts to spin
backwards, your problem is the laser pick-up assembly or the servo
control circuit. If you continue to have problems after cleaning and
checking the other things listed above, you may have a problem with the
player's alignment. Of course, one of the problems you'll face checking
alignments on a DVD/CD player is that you’re going to need to use an
oscilloscope on most of them. If you have the proper tools and
equipment, the first thing to look at is the RF pattern of the unit
while its playing. It should be a sharp and clear pattern. If it's dull
and smeared, then the laser could be weak.
Also, in these units
are very critical alignments called the focus/tracking gains and
offsets. When these alignments are off, it can often cause intermittent
troubles. As the unit ages and parts change value, so do these
alignments, and will need to be checked. In my time as service
technician repairing DVD/CD players, 65% of the laser pick-up assembles
I have tested were good and only needed a small adjustment. Today's
technology makes it unfeasible for a shop to hook up a DVD/CD player,
and even some recorders, to their equipment and make these adjustments
because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
