Question about Tally Line Matrix T6100 Printer
Tally 2365 set ip address - Tally Line Matrix T6100 Printer
2 Suggested Answers
LineMatrix
  • 34 Answers
SOURCE: how to configur tally tcp/ip address
take printer offline
press mode button
scroll up or down until you see TCP/IP displayed, then press the # 1 button
TCP/IP address is displayed, then press # 2 button
IP address class A is displayed, then press # 3 button
scroll up or down until you see 192 press enter for *
next press # 2 button again scroll until IP address class B is displayed, then press # 3 button again
scroll up or down until you see 168 press enter for *
next press # 2 button again scroll until IP address class C is displayed, then press # 3 button again
scroll up or down until you see 145 press enter for *
next press # 2 button again scroll until IP address class node is displayed, then press # 3 button again
scroll up or down until you see 69 press enter for *
You need to repeat this procedure for the Subnet mask and Gateway...
I'm sure you have fixed your problem by now, considering your request was Mar 19, 2009
Have any questions
Call x311
Posted on May 11, 2009
Is this unit (Tally 2265+) possible for LAN interface? If that so, can you give me a step by step method to do. Thanks!
The 2265+ has a LAN interface as standard, you do not need to install any options.
You can set the IP Address Via the control panel, go to the I/F section then select "Eth".
Set the IP Method to STATIC if you manually want to set an IP address.
By default the 2265+ has DHCP enabled so if you have a DHCP server the printer will obtain an IP address.
You can confirm the IP Address by printing out a configuration menu page;
Start with the printer Powered OFF
-Press and HOLD DOWN the SETUP button, and power the printer on.
-When the printer finishes initialising release the SETUP button. (this unlocks the menu)
-Ensure the printer is OFFLINE
-Press the SETUP button
-Press the BUTTON under MENU on the LCD display(Button 1)
-Press the BUTTON under PRINT on the LCD display (Button 2)
-The printer will print a menu configuration.
May 03, 2011 | TallyGenicom 2265+ Matrix Printer
Tally t2133 by hp print server
Access the the JetDirect settings, this is normally done by accessing a web page on the print server (enter the IP address of the print server in a web browser) Locate the Parallel Interface settings for the print server and set the following type of options; Speed of Connection- Set to the lowest available Bi-Directional Communication- Disable this you may need to select a standard parallel intrface type
Oct 07, 2009 | Tally Computers & Internet
How to share tally
First you installed the printer in one PC & share it.now you can go another PC & go to start>run>\\ IP address of the PC which printer is installed>enter
now you will find the printer.now right click of this printer icon & then click to connect.now your printer will be connect with both Pc's.
Sep 30, 2009 | Tally T2250 Matrix Printer
I'm not having a problem but I just need the procedure on how to change the IP address on a T2280 Tally printer.
If the printer has an internal network card the easiest way to change the IP address is through the printers own Web page, this can be accessed by entering the current IP Address of the printer in your Web Browser.
Go to the Advanced Section, then TCP/IP you can then change the IP Address of the printer.
You can find the current IP Address set in the printer by pressing the small black test button near the network port.
Alternatively you can use ARP for help on this open the DOS prompt and type ARP /?
Follow the example showing how to set an IP Address you will need the MAC address off the print out from network card test page.
Apr 21, 2009 | Tally Matrix T2280 Printer
How to reset the NIC to use DHCP
If you press the test button once on the network interface (a small black button near the network port) This should print out the network settings, you can then confirm the IP Address etc set on the printer.
I belive the defult setting on the network card is for DHCP= OFF, so if you default the network card you may not get the result you required.
The netword card can be set to defult by holding down the test button for more than 10 seconds. This should reset the network settings to factory defults.
You can unlock the menu on the 6312 by pressing the MENU and ENTER buttons and keep them held down for 5 to 6 seconds you can then access the menu.
The IP Address, Sub Net Mask and Gateway can be set via the control pannel menu on the pritner.
If the IP Address set in the pritner is valid for the network you should be able to get to the printers web page, you can then make changes to the pritners and network card configurations.
Mar 28, 2009 | TallyGenicom 6312 Matrix Printer
How to configur tally tcp/ip address
press mode button
Have any questions
Call x311
Mar 19, 2009 | Tally Line Matrix T6100 Printer
Tally T8006 Network set up
You can access the the NETWORK men on the T8006 by powering the pritner ON holding down TRAY
You should then be able to change your IP Get method and network settings.
Exit the menu by pressing the UP Arrow untill you see RESET on the display, then wait wilst the pritner restarts and it should have saved the new network settings.
Dec 28, 2008 | Tally T8024 Laser Printer
Tally T8106
The T816 can be used with Vista and XP over a Ethernet connection....You will not however be able to 'discover' the printer on the network.You need to set an IP Address in the printer or if the printer has been allocated a DHCP address you would need to find out what address has been allocated.
Once you know the IP Address you would need to install the printer on a PC/Server then share it to other users to be able to 'see the pritner on the network'
Once the pritner driver has been installed you can create a network port in the pritner driver to print to the IP Address of the pritner in the follwing way (on XP, Vista will be simmilar)
· Open PRINTERS folder
· Right Click on the printer driver for the T8106
· Select PROPERTIES from pop up menu
· Click on the PORTS tab
· Click on the ADD PORT button
· Highlight STANDARD TCP/IP PORT
· Click on NEW PORT
· This should open the TCP/IP Printer Port Wizard, work through this entering the IP Address and Port Name. Windows may try to detect the port configuration required.
· If the type of port is not automatically detected click on the CUSTOM radio button.
· Click on the SETTINGS button
· Change the PROTOCOL to LPR
· Under LRP SETTINGS enter the Queue Name as PASS
· Click OK.
· Click NEXT and then FINISH to finish the TCP/IP ports wizard.
Oct 27, 2008 | Tally T8106 Laser Printer
Tally Line Matrix T6100 Printer Logo
57 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
