Question about HP Computers & Internet
Surface Scan Test Error Code HD535-2W
Vista
  • HP Master
  • 7,627 Answers
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
How to fix InPageCoFire error
this is a decide error code. Your hard drive may be having problems. I would suggest doing a disk scan
CHKDSK /R /F
as well as system file scan/repair
SFC /scannow
Do this from a DOS command line (make sure to run as administrator)
ex.
http://www.howtogeek.com/howto/windows-vista/guide-to-using-check-disk-in-windows-vista/
Feb 22, 2015 | Microsoft Windows 7 Home Premium 64BIT...
Black copy problem
Subject: Full page solid image or error code C3200
Model: FS-6025MFP
Phenomenon: A full page solid image may appear on the print-out or error code C3200 (Exposure lamp
error) may occur.
Cause: The digital transistor in the CCD power supply circuit at the main board may be damaged,
resulting in the CCD failure.
Field measure: When the above mentioned phenomena occur, please replace the Main board with the latest type
(Parts PWB main assy).
Nov 02, 2014 | Kyocera FS-6025MFP Laser Multifunction...
Canon 8400F will not scan, error code 5, 155, 45
If it passes 'test' from the computer, then it should be listed in the Device Manager. Uninstall / Remove that device, then Restart and Re-install it.
Tallon41
Aug 22, 2012 | Canon CanoScan 8400F Film Scanner
On a monthly hardware diagnostics check,a surface scan failed the test.Is there a free tool to fix this problem avbailable to download?
This error often means that a physical spot on the hard drive has failed. Additional spots are likely to fail soon. Back up your data (build a recovery disc set if you haven't done so) and then get a new hard drive to replace the old one as soon as possible. (You may want to get drive cloning software - which will copy even the hidden recovery partition to your new drive.)
Rarely, the error means that a file is corrupted on the disc. Programs like SpinRite, http://www.grc.com/intro.htm , or HDD Regenerator, http://www.dposoft.net/ , may solve the problem. I'd still plan to invest in a new hard drive.
If your computer is still under warranty (with an extended warranty since you list Vista as the OS), contact the manufacturer about the problem.
I wish that I had better news for you.
(Drives will fail. This scan is meant to let you save your data before the drive completely dies. Since you have Vista, the hard drive was assembled at least 3 years ago and could be more than 6 years old.)
Mar 31, 2012 | Microsoft Windows Vista Home Premium OEM
My windows vista dont have internet and sound
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors. Open Internet Explorer
  • Open the Tools menu
  • Select the Internet Options menu item
  • Open the Advanced tab
  • Check the box next to "Disable script debugging"
  • Remove the check next to "Display a notification about every script error"
  • Click the OK button
  • reset all setting, clean registry key for internet explorer use registry cleaner reg in out to scan ur error
Sep 07, 2010 | Microsoft Windows Vista Ultimate Edition
During the monthly test: Hardware Diagnostics Tools- Scheduled Maintenance ... it shows that the surface scan test HD535-2W failed ...so do I need to fix this? and how???
actually it just test your hardware, but you can still use it, it actually says that bad sectors cannot be fix, something like that, try to scan it and fix error.
Sep 30, 2009 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Minolta Dimage Scan Elite 5400 - Vista driver?
1) Install all of the usual Minolta software in Vista if you haven't already.
2) Create a new folder somewhere
3) Create a new txt file in that folder and name it minolta.inf and paste this into it:
; minolta.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. Once installed, all the normal Minolta programs now work just fine. Enjoy!
I tested this on Vista 32 Ultimate with a Dimage IV but it should work on all the models listed in the .inf file.
Aug 02, 2008 | Minolta Dimage Scan Elite 5400 Film...
Computers & Internet Logo
306 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
