Question about Refrigerators
Hose in the back is broken. Leaks..and water dispenser does not dispense
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
  • 146 Answers
SOURCE: water dispenser leak
I think I would think about getting a new one. It would cost more to fix it and then you may not get it back together so it wouldn't leak.
Posted on Dec 29, 2007
dcp2
  • 63 Answers
SOURCE: Water leaks from tube at the bottom of fridge for water dispenser only
If it is a plastic compression fitting you can tighten each one a little(careful not to tighten them too much cause they can strip out) Use a small crescent wrench with a back up wrench.
Posted on Jan 28, 2008
  • 489 Answers
SOURCE: water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Posted on Apr 27, 2008
SOURCE: Kenmore water dispenser not working, side by side frig
no water come out of dispenser to glass
Posted on Aug 06, 2008
SOURCE: Water dispenser leaks of my whirlpool refrigerator gs6shaxk b01
on the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside.
Posted on Dec 31, 2008
Water dispenser leaks when pooring water
you have a broken water line.
needs to be replaced inside door.
Apr 03, 2014 | Frigidaire FRS26R4A Side by Side...
GE side by side leaks water from underneath when you use the water from front door
you need to remove the toe kick panel grille below the front doors on the refrigerator behind this grille there is a connector and it can come loose,also possibly the water valve in the lower rear behind the back panel can leak,have a helper press the door paddle for water and check all these areas for leaks,if it leaks from the door stem where the water line goes up the door to the dispenser,then you will need to pull new hose up to the dispenser from the collar mentioned at first,some refrigerators can not have new hose installed due to the door has been foamed internally at the factory and cant be dis-assembled,then you would need a new door with the hose installed
Apr 08, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
The water supply hose where it enters the door at the bottom has cracked and broken how do we replace the hose in the door
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 06, 2012 | Refrigerators
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water leaks out of the automatic dispenser
Slow down the water flow from the tap( Turn the tap on by about 1 or 2 turns). I have the same problem. the dispenser system cann't handle the volume supplied by the house system.
Sep 30, 2008 | Maytag MAH8700A Front Load Washer
Water gushes out dispenser
Something has gotten into the fill tube hose of the tub.  You will need to pull the drawer out and look down in the dispenser assembly to see if there is something blocking the hose.
Dec 30, 2007 | LG WM-2077C Front Load Washer
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
