Question about Ovens
Amana wall oven cuts off when heating. Model AOCS3040WW, Mf P1132375NWW
Our Amana wall oven, model number AOCS3040WW, manufactures number P1132375NWW, cuts off when heating. The oven will heat up, but at some point during cooking the oven will shut off. The time showing on the clock will disappear and will be replaced with blue LED blinking lines. The oven controls will be unresponsive and the oven will not heat. Once the oven cools sufficiently, the time will return and the controls can be set and the oven will heat up. During the day when not in use, the oven clock will randomly begin to blink. The time will be correct. Pressing Cancel will temporarily stop the blinking, but eventually at some point the clock will begin to blinking again.
  • 288 Answers
SOURCE: GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Posted on Nov 11, 2007
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
SOURCE: Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Posted on Nov 02, 2008
  • 5 Answers
SOURCE: Can't set date
Download the user manual (P23-DH III) from here:
Posted on Jan 10, 2009
  • 360 Answers
SOURCE: Random screen
I'd try reinstalling. Can you connect to the computer and use ti connective software. You can download everything from the ti web site. need more help to step you through it email me at:
Posted on Aug 27, 2009
Have perfectly working Caloric Electric self-cleaning Wall oven and broiler EXCEPT oven light went out and when we went to replace it fabric around gasket was disintegrated. All we need is the fabric...
while i'm here , give the fabric a flame test with a torch or lighter, just to make sure. some are more flame resistant than others. should be listed on the fabric roll label. good luck again! also, some appliance stores may sell do-it-yourself heat gasket materials.
Nov 04, 2013 | Ovens
Oven wont heat, shuts down in few seconds
Sseem issue with the thermostatic.
Aug 30, 2008 | Ovens
SEARS / KENMORE Range/Stove/Oven Manufacturers
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances. This chart will help you determine who actually built your appliance, then you can choose the manufacturer from the charts on this page.
The first 3 digits of the model number determine who built your Sears / Kenmore Unit. This can be helpful if looking for repair or replacement parts.
Your model is manufactured by the following if your units first digits starts with:
Amana 596
Caloric 174 / 960
D & M 587
Fedders 484
GE 362 / 363
Gibson 253
Jenn Air 829
Kelvinator 417 / 628 / 662
Litton 747
Maytag 925
Roper 103 / 155 / 647 / 835 / 911
Speed Queen 651
Tappan 79
Toshiba 562
WCI 790
Whirlpool 106 / 110 / 198 / 562 / 665
on Jun 10, 2011 | Ovens
Trying to find piece of heat resistant fabric (don't know name - something like old asbestos) to replace degenerating fabric on light fixture gasket on otherwise perfectly working caloric electric wall...
If it would help you to find the model number, I would look for a way to remove the oven door. Usually there will be a release near the hinge bracket that you push in or push to the side to allow the bracket to release and you can remove the door to see the ID plate. Otherwise, I would suggest going to a wood stove dealer and looking at the door gasket material they have in stock. They usually have rolls of heat resistant gaskets for sealing doors and glass panels in wood stoves. Last idea would be exhaust gasket material available at Napa Auto parts. Good luck!!
After cleaning the top half oven with a self-clean cycle the oven will not pre heat past 100 degrees. The bottom oven will heat. What might be causing the top to malfunction? The serial number is...
usually it is the thermal cut off( TCO) ,a kind of themal fuse which goes out if the temp exceeds certain limit and cuts off the power to the is to protect the cavity from over needs to replaced or reset depending the model. u will need a tech to fix this.
Aug 21, 2009 | Electrolux Ovens
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
May 31, 2009 | GE JTP20 Electric Single Oven
Cant find serial number - model AOGD2750
open the doors it should be on one of the door frames on a metal tag
Mar 24, 2009 | Amana AOGD2750 Gas Double Oven
Amana wall oven will not heat with new ERC
the heating element needs replacement.that the only solution.its common in this ovens as the heating element breaks down in between so it never heats up.
Mar 03, 2009 | Amana AOES3030 Electric Single Oven
Ovens do not come up to set temperature
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Feb 16, 2009 | Amana AOGD2750 Gas Double Oven
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Ovens Logo
64 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
