Question about Saeco VIA Venezia
Knocked out spent coffe grounds come out mushy not like a puck
Mushy spent grounds and after removing coffee filter holder there is water leaking brew unit this is a new unit got it for Xmas have tried different grinds with a burr grinder , tried tamping ,light ,harder and no tamping dosent seem to make a difference
  • coffeeholic Mar 08, 2009
    I have the same problem, I find 'coffee ground soup' with I look to empty the grounds. It takes an entire minute to get two shots of the machine. Soupy grounds problem started about same time as 'it takes a entire minute' to get two shots out of the machine.
    President:
  • 1,618 Answers
Adjust the grind on the machine, or the amount of coffee the grinder puts into the chamber.
Posted on Mar 25, 2009
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Will not process the water to make coffee
the coffe maker might be clogged up so here' what to do: Look through the clear plastic panel on the side of the coffee maker's water tank to make sure that it has water in it.
  • Clean your Sunbeam coffee maker, You can wash the removable filter basket and carafe in hot, soapy water and pour 4 cups of white vinegar into the water reservoir of your coffee maker. Start the brewing cycle with no coffee grounds to allow the vinegar to clean the inside of the coffee maker. Rinse away the vinegar by running the brewing cycle twice with only clean, fresh water.
  • 8 Check the removable filter basket to see if the filter has collapsed if you find coffee grounds in your brewed coffee. If the paper filters collapse often you can wet them before you place them inside the filter basket so that they will stick to the basket and stay in place. or check this link because it might need a new hose. Coffeemaker Sparepartswww.coffeemaker-spareparts.
  • Jun 12, 2011 | Sunbeam COFFEEMAKER 10C BLACK DR13
    Machine leaking water from service door behind where the pucks collect. water pools/collects into the excess ground coffee tray. any suggestions?
    Hi
    Trying to understand what you are talking about, but if you have water in the top left side of the brew unit, its your thumb screw. If you have water under the brew unit Its the drain for the pressure release. remove the brew unit. The injector behind the brew unit on the machine has a drain and it can get clogged with coffee residue. If there is water below the injsctor the drain hole is inside and towards the front of the machine. A long zip tie inserted in the drain aimed down towards the front will usually find the drain hole and clear it, then take some hot sudsy water and flush the drain.
    If its the thumb screw you will ahve to get a new one but be sure to remove the extra nut on the filter screen shaft before installing the new one.
    Jan 01, 2011 | Saeco Magic De Luxe Espresso Machine
    Gaggia Titanium. . coffee not hot even though
    Remove the filter holder and brew some water into a small plastic cup and check temp, it could be the thermostat for the coffee temp is damaged.
    Apr 29, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
    The brew unit is not tamping the ground coffe properly.
    Give the brew unit a good wash,then lube all the moving parts with food grade grease.
    If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
    Feb 21, 2010 | Gaggia Titanium Espresso Machine
    Cafe Roma Expresso/Cappucino machine
    My understanding is that this is normal with units like the ESP8XL which use a pressurized portafilter. Non-pressurized units will leave a dry puck of used grounds.
    Nov 28, 2008 | Breville ESP8XL Espresso Machine
    Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
    It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
    The gold permanent filter must be cleaned between each brewing cycle.
    Try this:
    1. Remove the filter basket from the coffee machine.
    2. Remove the gold permanent coffee filter from the basket.
    3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
    4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
    5. Fill the water reservoir with the desired amount of water.
    6. Add the desired amout of coffee grounds into the paper coffee filter.
    7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
    8. Ensure the glass carafe is placed correctly in its position on the heating plate.
    9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
    Hope that helps.
    Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
    Saeco Incanto - Water Light will not reset
    actually it sounds like a blocked filter from the brew group.
    Take out the brewgroup and iether with your key (sometimes not in the box) or with an allan head remove the filter.
    Check the filter by holding it against the light for obstructions.
    Clean with needle
    I guess this might well be your problem
    And if you use hot water by the way instead of steam the water light will go out faster.
    If your warm water works you have no problem with your boiler
    May 02, 2008 | Saeco Incanto Classic Espresso Machine
    Saeco VIA Venezia Logo
    287 people viewed this question
    Top Saeco Coffee Makers & Espresso Machines Experts
    espressofixr
    Level 1 Expert
    just-ice
    83bj60
    Level 1 Expert
    Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
