Picture is dark
I have a Phillips Magnavox big screen model # 9P6444 C103 and the picture is very dark and is best watched with the room lights off. What needs to be replaced or fixed? Any estimate on possible parts to fix it? It was given to me because someone didn't think it was worth fixing but it appears to be in excellent condition - it is only 8 yrs old. Please help. I will take the time to rate your help and input. Thanks.
  • 43 Answers
On projections, there isn't much you can do as they age accept replace the CRTs. In that case you might as well buy a new one. One thing you can do is open the front speaker grill to where you can see inside the set. Depending on the brand, find the "Screen" controls, one for each tube. Some sets have all 3 on the "focus/screen" block (small black box mounted in front) and some have the knob on each individual CRT board (mounted to the bottom of the CRT). What this does is increases the current to each tube, thus making that colr brighter. Do each equally as to keep the color balanced. Only do this if you feel comfortable with working on electronics.
Posted on Jan 12, 2009
Phillips 47PFL422D/37 I've had the tv about 6 years with no trouble. But now the picture is to dark to watch it also pulses. I've tried to unplug it and plug it back in I get a picture for
First, average life on these sets is about 3 to 4 years at best and only boards are sold so even if you can pin point the board (no individual parts are sold) it is likely if will not get fixed and doing so is a bad investment as all the boards are now old.
Dec 04, 2012 | Televison & Video
Phillips magnavox big screen rear projection tv
Base from the description that you gave us this is really a symptoms of a bulb that is going bad and needs replacement already, because it will just go bad dark as time goes on so it will be better for you to have the bulb replace as of now ....
Good luck.........
Aug 17, 2008 | Televison & Video
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a phillips magnovox big screen (March 2000) model # 9P6444 C103 - the picture is very dark and is best watched with the room lights off... what needs to be replaced or fixed?
The coolant fluid in the blue and green picture tubes is in need of changing.Unless you have done this before I do not recommend that you attempt this repair.A shop shoud be able to make this set look like new again for about $275
Jan 11, 2009 | Televison & Video
White corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Magnavox 27 Inch TV- no picture but has sound
the vert. circuit need to be rebuilted
Aug 04, 2008 | Televison & Video
My TV
One of the most common faults with the phillips rear projections is the coolant in the tubes. That can and will make the picture very dim and can cause the brightness and focus controls not to have much affect over it. Please respond to this same post with your model number and I will check to see if their are any other items that could cause that symptom.
Jul 01, 2008 | Televison & Video
Picture issue with Philips 64" Big Screen
don't know if this is same problem or not but try this:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.keohi.com/keohihdtv/brandspecific/philips/philips_convergence_geometry.html
Dec 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
