Question about Rotary Bosch 11536vsr 36v Sds+ Roto Hammer Drill Cordless
Hi I've got a bosch 36 vf li and I'm struggling to open it up to change brushes. I've undone all visible screws but still struggling with top part of unit.
I don't want to pull at it too much as it feel like its going to break.
    Champion:
  • 304 Answers
Have you removed the 4 gearbox screws? the cover should lift off. sometimes if a brush holder has over heated then the two halves get stuck together in places.
Posted on Dec 17, 2012
  • Tony c Dec 17, 2012
    Hi many thanks for reply, have taken the four screws out, but I do think it over heated!! Do I gently tap it with a hammer or just bite the bullet and send it in for repair?
How do i change the chuck of a bosch psr 10,2 li cordless drill
Hi. When the 3 pins are opened all the way there is a phoenix type screw in the centre of the chick.(inside where the drillbit comes) There you can hold the chuck with hand or bench vise and unscrew the bolt holding it secure. spray some wd 40 on the base and gently wiggle it out.
Feb 26, 2015 | Bosch Drills
Reverse is forward and vice versa
To get a dc motor to spin in reverse you have to change the polarity of the battery. This is normally done in the switch by which set of poles is connected . Have you connected the battery up correctly in the first instance.
Jul 13, 2013 | Minn Kota Endura 40 Transom Mount Trolling...
Replacing brushes Bosch impact driver
If it has the replaceable brushes it should be no problem, just unscrew and replace. Try oasistools.co.uk
Dec 28, 2012 | Bosch Gdr18v-Li 18V 2-Speed Multi-Function...
How do you change the brushes on a bosch 36 v-li
Once you have removed the 4 screws holding the gearbox to the main body take off the right hand half of the housing leaving the left half on the work bench. Unscrew the 2 screws that hold the brush holders down and remove the old brushes and refit with new ones. Rebuild in reverse.
Oct 24, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
I've just changed the brushes on my Bosch washing machine motor, but it's still not turning the drum! Is there anything else i need to reset?
1) Test the lid switch must be closed very well, this will NOT start the machine.
2) the start button test for open
3) tight any wires connector
4) see the outlet box from your house is o.k reset the breaker.
5) put some desklamp for to see if working, so go and test the power cord .
6) tight the fuse or c.breaker from control board.
6a) put correct tension in the belt, see for any obstruction mechanical with the clutch and brake see the diagram
7) try it
Jul 18, 2012 | Bosch Washing Machines
Hello I've got a Bosch classic 1200 wfo246 washing
Bosch classic 1200 wfo246 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 26, 2011 | Bosch Washing Machines
Code f43
Bosch 'F43' stands for 'motor fault'.
Motors- and belts, which are sensible to change at the same time- are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts, normally 2, should be loosened and the belt removed then remove the bolts completely
With the motor it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished. Refurbishing includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit firmly on the commutator but straddle it- the centre is often more worn than the outer part.
Unfortunately motors are not cheap- the motor for our 18+ yearold Bosch cost GBP250 but it will probably outlive us!
Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 14, 2011 | Bosch WAS24460UC Front Load Washer
I've just purchased a Bosch BX1 1600 vacuum cleaner in Spain, and already I've lost the hard furnishing brush, the crevice nozzle, the upholstery nozzle, and the hard-floor brush that I think were...
Hi Dave,
Are you in the USA? If you are, try this web address: >>>> http://www.bosch-eshop.com/eshop/bosch/us/brushesfloortools.htm
Copy and paste the address into your browser and the tool page will open up for you.
Should you want to shop in the UK, there are a lot of shops that carry them. Just do a google search for your make and model plus the word "attachments" and you'll see several from UK.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 02, 2011 | Bosch Vacuums
How to repairreplace brushes for 36 volt bosch lion batt drill
There are black access panels on each side if the drill toward the rear. Remove the screw that holds them in, and remove the panel. This will expose the bruch holder, take a small screw driver and carefully remove the old brushes and replace them. Replace the panels.
Jan 24, 2010 | Bosch 36V Litheon Drill/Driver With 2...
Rotary Bosch 11536vsr 36v Sds+ Roto Hammer Drill Cordless Logo
226 people viewed this question
Top Rotary Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Rotary Drill Expert? Answer questions, earn points and help others
