Hi my mum took the front filter off and can't get
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
Hi can any1 help me with my nissan sentra problem?my car just shut off while driving and lost power be for it shut completely off tried to crank it back up but it didn't start sprayed some starter
Crank shaft sensors often fail without triggering a code. But in its early stages, a check engine light may be on. Symtoms of a bad crank sensor are: poor acceleration ( lack of power ) rough idle, ETC. sometimes you may be able to start it normally, and other times it takes 3 or more times. If the check engine light is on take it to a auto parts store and thy can read the code for free. To tell if that's the problem. God-Bless!
Apr 18, 2013 | 2004 Nissan Sentra 1.8
Took left hand side sump plug out and tapped spring came out not sure witch way 50cc 4 stroke kids skyteam ?
Put spring in first, now put dome filter on your finger, then 'into' spring, then cap back on. Best o luck.
Mar 25, 2013 | Motorcycles
Location for fuel filter on a 1997 Ford Thunderbird
Find the fuel filter shield. It is by the muffler. Remove the shield and you have direct access to the filter.
Feb 13, 2013 | Cars & Trucks
Why my acer aspire e1-571 won't shutdown?
i would take it back straight away if you start messing with it they might accuse you of damaging it and decline the warranty on it....
Jan 04, 2013 | Acer Aspire E1-571-6650 Laptop
Frigidaire front load washer code error E20
Hi, this error is caused by a clogged drain filter located under the drum assembly.
If your machine is stuck on the drain sequence or you read error code E20, the filter basket is probably clogged:
You will need a pair of slip-joint pliers and a Phillips head screwdriver.
Before beginning any work, make sure to unplug the machine from the electrical outlet.
**Note: It may be easier to perform this task with the washer lying on its side; therefore it may be necessary to disconnect the water lines from the machine.
1: Take off the front kick plate (two screws at the bottom of the machine).
3: There is a black accordion hose with two clamps.
2: Have a towel ready to catch the water that leaks.
4: Remove the clamps at each end to access the filter basket.
5: Stick your hand inside the hose and remove the plastic filter basket (it will probably be clogged with hair, lint, fabric).
6: Thoroughly clean the filter basket and remove all debris from the inside of the black accordion hose.
7: Replace the filter basket.
8: Reattach the black accordion hose at both ends.
9: Secure the clamps at each end of the hose.
10: Wipe up any water that may have spilled inside the machine.
11: Reattach the front kick plate with the two screws removed earlier.
12: Reconnect all hoses before plugging in the machine to the electrical outlet.
Thank you.
Jun 06, 2012 | Frigidaire ATF6000ES Front Load Washer
No cold water enters tub. Everything gets washed hot no matttter what the setting.
You water line filters may be stopped up. This happened to me once and I unscrewed the two hoses next to the machine and looked. There was a filter that I could remove, made of hard plastic. I took the filters out of each hose and screwed the hoses back on the machine, without the filters. It worked for years. The other thing that I have done is I once had a machine I couldn't get unclogged and the line didn't work for my cold water so I turned off my hot water and I took the hot water hose and put it to the cold water tap. My cold water came into the machine by the hot water hose. I used it for years afterwards. I just had to wash everything in cold water.
Jul 16, 2011 | Siemens WFXD5200UC Front Load Washer
My mum put her laptop on hibernation, and took it downstairs and now she can't turn it back on.
May be an unrelated problem to placing the computer in hibernation.
Try removing the AC adapter
Then remove the battery for about a minute
Put battery back in
And try and reboot it
Nov 01, 2009 | Compaq Computers & Internet
I have f18 message and need bit of help with the solution
We had the same problem with opening the pump cover;
The solution was taking more of the washing machine apart because there was something blocking it from the inside and preventing it from opening.
Trying to force it may cause more damage so unplug everything and tip it backwards - no need to lie it flat, do it just enough so it is stable and doesn't fall over.
Take off the front bottom panel on the machine.
Undo the screw holding the filter housing to the front of the machine and lower it inside the machine, next unscrew the hoses and disconnect the wiring from it. This will allow you to pull the filter out completely and to open it up.
Clean the pump, check that there's nothing in the pipes/hoses and then put it all back together again in reverse order to which you took it apart in. (i.e. put together the last part you took apart and work backwards).
Sep 14, 2009 | Bosch Logixx WFT 2806 Front Load...
Mikomi Mobile Webcam drivers
i dont no wat to do aswell i have computor but 4 ma bday ma mum & dad bought be a laptop but i lost the driver too does any1 no where to download a driver from ?????
Dec 16, 2007 | Micom (VIP-4004-ISO-DX) (VIP4004ISODX)...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
