Hp mini 110-3600sa keyboard stop working
Hello i have a problem with my hp mini the keyboard has stop working it boots up ok but no keyboard I have removed the hard drive it don't even goto bios and when it said there is op system press any key i have pressed all off them nothing and my mouse pad only works on Linux not xp when I last used it it was fine I shut it down and went to start it up the next day any that when the problem started I don't understand please help
  • diablo401972
    diablo401972 Dec 04, 2012
    thanks been there theres nothing about it for my model thanks for help anyway
    Problem Solver:
  • 6 Answers
Motherboard or keyboard problem , go to your manufacturer's support,
Posted on Dec 04, 2012
SOURCE: mouse pad
I have this problem every now and then. For a quick fix, I goto the toolbar next to the time where it has the Synaptis Pointing Device Icon, a box, with two boxs under it (like the mouse on the laptop) left click it -> Pointing Device Properties -> Device Settings Tab, highlight the device and click DISABLE, it'll ask if you are sure you want t disable it -> OK. Then simply, click it again, and ENABLE. This like, "resets" the mouse, mine works everytime.
Posted on Oct 06, 2007
  • 883 Answers
SOURCE: Acer laptop booting only if battery removed and on main power
try disabling ACPI (Advanced Configuration Power Interface) in BIOS screen, if you have that option. Something does not agree with Windows control of all ACPI devices...could be the modem or ethernet network. Also, if no success, try disabling "allow this device to wake computer" for either (or both) the modem or ethernet network devices in control panel-system devices option screen.
Posted on Nov 26, 2007
E500
SOURCE: boot sequence problem
bios satup key
Posted on Jan 14, 2008
  • 3 Answers
SOURCE: Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Posted on Aug 16, 2008
  • 733 Answers
SOURCE: Keyboard/mouse on HP Pavilion dv7-1240us is not working
go to start, control panel, performance and maintanance, system, hardware, device manager. If you see any question marks on any of the devices, then you need to reinstall the drivers for that device, but if there are no warnings then you may need check into it further.
Posted on Apr 01, 2010
Hp mini 210 keyboard
go into add remove hardware in the control panel and delete the aux keyboard
Apr 24, 2013 | HP Mini Computers & Internet
Hp mini 5102 keyboard is lock
the key may gone bad, need replacement or the connector may disconnected from motherboard
Jan 10, 2013 | HEWLETT-PACKARD HP Mini 5102 Atom N450...
Problem with Hp mini 210 laptop ,after login into windows 7 starter the screen is blank. How to fix this...?
Hello.
If your computer is dark after login, it usually means that your user profile is corrupted.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK.
Hope this helps.
Apr 08, 2011 | HP Computers & Internet
Hi I have a HP Mini 2140 and i have a problem regarding the letter "n","b", "f8" and "delete". they stopped working. what should i do? please assist asap
Change the key pad,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dm3-series-notebook/
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k02
http://www.insidemylaptop.com/replace-damaged-keyboard-hp-pavilion-tx1000-notebook/
Hope this helps
Jan 26, 2011 | HP Mini 1000 Netbook
HP MINI keyboard letters doesn't want to work
the letters of n, b and six, seven of my HP Mini 110 keyboard would not work, what should i do?
Oct 28, 2010 | HP D8597A Keyboard
HP Mini 110 shut down during scan disc not booting up
Try hitting the F8 button on the keyboard a screen comes up with several options move to safe mode and hit enter on the keyboard if it boots up to safe mode hit the NO tab when it asks to go to SAFE MODE you then can do a system restore to a date that you know the computer worked....this is a restore not a recovery and you will not loose any of your documents or pics etc....
Jul 07, 2010 | HP Mini Notebook
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
Sony vaio wireless keyboard is locked, can not type. a symbol of a lock is showing on the mini screen that has a "1" in it. Please help.
Hello Vince...don't you just hate when that happens...it drives me crazy...Try this trick i learned...maybe it will work for you too.
Power down the lappy...remove the power supply. Hold the power on button down for a good 60 seconds. Reinstall power supply and boot up. I know this will work on a Dell..HP and Acer laptop....maybe we can add Sony to the list. If it dosen't work...i have a tech. manual i can dig out and we can try again.
Good luck...i hope this helps
May 18, 2009 | Sony VAIO Wireless Keyboard Kit...
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
