Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf162 built-in dishwasher error codes
When I start my dishwasher on a wash, just after it starts it fails and two error lights flash they are the dailywash light ( second from the left) and the eco wash light ( fourth from left). This combination isn't in the user manual so if anyone can help I would be grateful. Me too, never completes a cycle and stops in various stages, before and after the tablet has been dispensed, within minutes and then other times when itseems to have gone for ages.
It smells too, when it's hot, of cigarettes! I have quite a sensitive nose, but it does, it's awful. Today it seemed to go white too, in the door, whereyou would imagine the powder to dissolve down it, but a finger wipe removed nothing!!!
It's been a bad pup this dishwasher!! Has hotpoint out loads of times under warranty but now no longer is.
  • sheenavic Mar 01, 2009
    Hi i have the exact same issues with my dishwasher did you find a solution?
    sheena
Take out diswasher, tip it backwards and drain out water. make sure that salt resovoir is on tight and there are no leaks from the arms
Posted on Feb 03, 2009
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
My BF162 runs with the door open. I also cannot
Yup, could be that pesky door latch, or even the control panel board. This could be a case for a repair man or replacement, depending on the cost.
Sep 25, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Wash light flashes
Hi LIANNEshaun,
I'm Harvey the Master Plumber.
Your problem is: you switch on dishwasher and it seems to start then light goes onto wash and the machine stops and green light flashes
Could we have the make, model and year please?
Feel free contact me again!
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Hotpoint bf162
after the 20 seconds does it restart
Feb 25, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Feb 10, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
BF162 Hotpoint intergrated dishwasher
consult manual under troubleshooting.
if no manual, or if it does not address this, consult service center.
one likely cause you can try first is to disconnect it from power via the cord or a breaker. after a brief period, it may reset itself.
otherwise you likely have a logic board issue.
logic boards seem to be very vulnerable in dishwasher environments. the type of issue you have is very common among most brands. don't feel alone.
good luck
mark
Dec 28, 2007 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
862 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
