"I have a Leisure Fridge/Freezer HJA6100. It is not cold enough and the freezing is not freezing correctly anymore. The error notification E4 is showing up. I was told it may be the Defrost Controller. I have ordered the Sensor part but don't know to fit it..."
SOURCE: E4 error on new conia dishwasher
I have a Maytag MJD3000AAW dishwasher and it was showing E4 during a cycle. On checking the pressure tube from the outlet of the dishwasher to the nozzle on the u tube under the sink, I fould that the dishwasher was not draining properly as a kink have developed in the tube where it curved back to the nozzle. I slid the pressure tube into a long elbow which stopped the tube from pinching. Problem solved.
SOURCE: E4 ERROR
i have had the same problem,saw this add and got to it straight away,excellent info worked a treat,thankyou very much
SOURCE: bELLING IDW604
i have just fixed my e4 code problem
take off salt cover and remove all water with tea towel or dish cloth you must make sure all water is out switch off at wall then back on if still e4 reapeat getting water out my washer is cleaning as i type
SOURCE: idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
