Question about Sony Ps1 Asciiware Arcade Joystick Controller Playstation 2
Can i play no one lives forever with asciiware joystick on ps2
I plugged my asciiware joy stick into my ps2 but it is asking for a dual shock controller .
burns-o
  • 114 Answers
SOURCE: can't get ps2 dual shock 2controller to work
you need to do a special code to take control which is press L1,R1, L2, R2, Start, and Select, for about 30 seconds. if it don't work, unplug the controller, blow on the Female and Male ends. (controller and system) and plug back in and you should be good to go. Please rate my solution.
Posted on Jun 10, 2008
  • 15 Answers
SOURCE: My ps2 anolog dual shock controller wont work!
It could be the PS2 connector port.
1) Try cleaning it. Maybe used compressed air or just blow into the faulty connector port.
2) Something more challenging, is to maybe open up the PS2 and to search for any broken connections between the Ps2 controller port, and the Motherboard of the PS2. Use a phillips #0 or a phillips #1 screwdriver, flip the ps2, you will see all these tiny squares, pull them out using something sharp, and underneath them there will be the screws, also there are some screws located underneath the warranty sticker and another underneath the Info sticker, just probe the surface until you land upon a hole. there you will find the screws. Open the ps2 up and you will spot the connector and search for any broken connections. any broken links can be fixed just by using a soldering iron and some solder.( OPENING UP YOUR PLAYSTATION VOIDS YOUR WARRANTY).
3) IF your ps2 is still under warranty, you can send it back to sony, or one of their many repair centres around the nation( IF U ARE IN THE USA). If in another nation, you can visit sony.com and follow their instructions on how to go about with in warranty repairs
Posted on Dec 31, 2008
hk_danni
  • 67 Answers
SOURCE: ps2 dual shock2 controller buttons not working
Removed accumulated dust sticking on the board were the buttons touches.use cotton balls with alcohol or use clean damp cloth.If nothing's happen check the cord I'm sure it is twisted badly, open your ps2 use this controller and try to twist back the twisted cord if it stopped sometimes when your twisting it then you have to replaced the cord(make sure that your using the original ps2 controller not imitation)pls. rate
Posted on Jan 30, 2009
nickey08vij
  • 14 Answers
SOURCE: ps2 dual shock black controllers are not recognized?
1.) i think u r controller pin is bend are broken
2.) or controller wire is cut
its better 2 buy a new controller
peace out >>>>>
Posted on Jul 26, 2009
  • 14 Answers
SOURCE: PS2 Controller Joystick Problem During Gameplay
If you've had the controller a long time weird things can start happenning. Usually the pads on the joysticks go first.
Try a different joystick(borrow a friends) and if it still happens you'll know its not the controller.Could be a glitch in the software of the game.
Eliminate each area. If a friend has the same game use their disc to try your controller with.
Take your controller to the video game store ask them to try it out on their game display models.If it's "busticated" you can buy a new one right away LOL.
Posted on Aug 03, 2009
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
Joystick sticking
You could try and take apart and clean moving parts, but usually its a quick fix that doesnt last. I suggest buying a new one.
Apr 13, 2010 | Sony PS2 Dual Shock 2 Controller...
Bought attack 3 joy stick -won't do anything
Try unpluging stick from pc,And changing port where its plugged into.
Next try unpluging stick and reboot pc,once pc is started,plug joystick back in.
Thanks and good luck
Jan 12, 2010 | Logitech Attack 3 Joystick
Aug 03, 2009 | Sony PS2 Dual Shock 2 Controller...
No vibration in controller
you have to seperately install the ******** driver which is provided with the joy stick..install that driver...it'll vibrate
Jul 05, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 joystick or ports problem.
Maybe you need a new controller that happend to me one time.
Mar 28, 2009 | Sony PS2 Dual Shock 2 Controller...
Right analog stick not working
Check the controls on the game's control section. If you play another game that uses the right analog control and it works on that game then it's the control set up for FIFA. Make sure that the analog control light is on when the game boots up. Sometimes if the analog control light is not on when you turn the game on and you turn it on afterwards, the analog stick controls don't work properly. That happened to me on NFS Pro Street. If this helped you leave feedback please. FIXYA!
Feb 19, 2009 | Sony PS2 Dual Shock 2 Controller...
PS2 doesn't play color
is u r ps2 modify if yes than try this
turn off u r ps2 and press 2 buttons togather trangle and cercle now turn it on u get one menu in u r screen and in first line of menu u get ntsc wrriten press X buttons u get it change turn it in pal o r ntsc
now press start button in u r joy stick it will display setting saved now turn off ps2 and turn it on now u get colours in u r games . REMEMBER U R PS2 SHOULD BE MODIFY SO U CAN DO ABOVE SETTINGS
WITH MODBO 3.0 IC IT WILL DISPLAY MATRIX WHEN U GET IT START U R PS2
Jan 16, 2009 | Sony PS2 Dual Shock 2 Controller...
Joystick Stuc
Sounds like a $10 ebay repair replacement joy stick. Have a good one.
Jul 09, 2008 | Sony PlayStation Portable (PSP) Console
Can't get ps2 dual shock 2controller to work
Jun 10, 2008 | Sony PS2 Dual Shock 2 Controller...
Sony Ps1 Asciiware Arcade Joystick Controller Playstation 2 Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
