My graphics card was filled with dust so i had to remove it, vacuum it and then i placed it back. But my sound was gone, the computer can't find my speakers, they don't have any driver cd'
In the mixer thingy it says that it's using is "Realtek Digital Output" and i can't change it to any else.
    President:
  • 949 Answers
You don't need a driver CD for speakers, your sound hardware needs drivers.
Just because you powered down and removed the card does not mean anything should have changed.
Look at your specs for your system and find out what sound hardware you have, then look for the sound in control panel, you might have to set the default to speakers, you can test them.
If you have video, then the graph drivers are ok.
Posted on Dec 06, 2012
chiplevel
  • 656 Answers
SOURCE: ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Posted on Nov 30, 2007
DRSS
  • 81 Answers
SOURCE: sound card problem for intel desktop board D101GGC
SkullyFox give the good solution but let me tell you one thing.....
If you by mistake installed the wrong drivers in the Realtek chipset sound then you have to remove or uninstalled the sound application …..
Intel Original all the boards having the same problem ….
Over the internet one patch is available for Realtek sound drivers first you need to install that patch after this also sound not came then try re-installing the Sound application…
Posted on Dec 10, 2007
Nic61
  • 1073 Answers
SOURCE: Graphics Card Compatibility with Asus M2A-MX motherboard
Hi Anli!
Well, any GPU with pci expess will be compatible thit that mobo of your.
Its not easy to recomend any specific, it all depends of what you needs are.
Just make sure that the card you upgrade with is for an pci express slot.
A verry good GPU coast around 150-200 euros, a top GPU card cost 400-600 euros
There are ATI cards and there are Nvidia cards, both will suit with your MoBo as long as they are for pci express.
Good luck with your new card M8!
please take a moment and rate my answer
Nic
Posted on Feb 06, 2009
odiebugs
  • 949 Answers
SOURCE: Intel E5200 Dual Core 2.50gHz
Go to devise mgr and look at the sound hardware under sound, rt click on realtek and click on properties, look at driver, does it say windows or realtek,and check version and date,then go to realtek
and see if the driver is the newest and the right one for your hardware.
That was great that you listed some info,but the wrong info,ex for OS, you should have listed the motherboard model #, you should post back the model# and what it said under driver,version,date of driver. Then someone can check to see if the correct driver is installed.
Posted on Mar 21, 2009
  • 226 Answers
SOURCE: cannot find medion 3500 motherboard drivers
Hi there is a peice of software that you can download.Do a search for Belarc and opt for the free version form the website. When installed it gives you a list of virtually everything on your system, including the key for your operating system and any other software.when viewing the results, look at the part that says MAIN CIRCUIT BOARD.Then go to the manufacturers website and download the appropriate drivers. I hope this helps you.
Posted on Jan 19, 2010
Computer overheating
Check the machine for dust, and us canned air to move it out. Make sure that your fans spin upon powering on your machine. Fan controllers can be downloaded to help boost fan speed and cool the machine. Make sure you're not placing the laptop on anything preventing airflow, like carpet or blankets.
Nov 10, 2012 | Dell Computers & Internet
My gateway profile 4 all in one has a totally white screen with no display. Rebooted with normal
before thinking about replacing the video card
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
if you need to replace the video card it will be attached to the rear of the vga lead inside your computer usually in a pga slot
Remove your computer's cables.
Turn your computer around so the back faces you.
Remove the two screws on the computer holding the right side of your computer to the case.
On many models of gateway computers, you only need to remove the screws with your hand. Remove the right side of the case to expose the interior.
Unscrew the metal plate of your old graphics card holding it to your computer's case. Remove the card by sliding it out of the motherboard.
Slide your new graphics card into the slot from where you removed the old one. Screw the metal plate to your computer's case.
Reassemble your computer and connect its cables
hope this helps
Aug 02, 2012 | Gateway Profile 4 All In One (MPN...
Screen turns red when computer loads
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Holmesmary17.
Your computer's graphics card is either overheating or the connectors are not making good contact. In extreme cases the graphics card is toast.
However I think a good clean will do the trick. One carefully cleans the gold fingered connectors of the graphics card interface with tissue paper. Then use a vacuum cleaner to get out as much dust as possible.
Reinsert the card, connecting the monitor cable again. Power on the system and see if there is a change.
You may need to take this computer into a computer store for repair.
Take care!
Apr 18, 2012 | MSI Computers & Internet
Monitor says no signal
Monitor states No Signal, because it isn't receiving a Video Signal, from the computer.
This can be from;
A) A bad monitor cable
B) Bad graphics card, or bad graphics chipset on the motherboard
C) Computer isn't working. (May look, and sound as though it is)
A1) If a flat LCD screen monitor (Digital), does it have a removable monitor cable, and do you have access to a working monitor cable of the same, to use for a test?
A2) If not, do you have access to another KNOWN to be working monitor, and cable? Use it for a test.
Or use your monitor and cable on a Known to be working computer.
Monitor and monitor cable prove to be good?
Next is go to the graphics card, or graphics chipset.
B1) Graphics Chipset:
Primer:
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
A graphics chipset is a GPU. Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
A GPU can be soldered directly to the motherboard. This is Integrated Graphics.
(Another term used for Integrated Graphics is OnBoard Graphics.
ON the motherBOARD)
A GPU can also be soldered to a removable adapter card.
This is a graphics card. Also known as a video card.
If the graphics chipset is though to be bad, a graphics card is installed, (Drivers FIRST, then physically install the graphics card)
You won't be using the motherboard, or Integrated Graphics anymore.
You will be using the graphics of the graphics card. This is how a graphics chipset problem is cured.
( If my data is correct, the eMachines T2240 Desktop PC uses an
FIC VL35G motherboard.
First International Computer {Inc},
http://www.ebay.com/itm/eMachine-HP-VL35G-865G-P4-Socket-478-uATX-Motherboard-/270778135974#vi-content
Has an AGP expansion slot { Brown slot above the 3 white PCI slots } for a graphics card )
C1) Computer not working
I think you can skip B1) and go here first.
Reasoning is, that 80 to 90 percent of desktop computer failure, can be attributed to;
Computer is dirty inside
Bad Power Supply
Start with computer is dirty inside.
Computer on a table, computer unplugged from power, computer case open. Follow Anti-Static Precautions, check out the condition of the inside of the computer.
[Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Computer on a table, computer unplugged from power, computer case open, TOUCH an unpainted surface, of the metal frame of the open computer case.
SHOULD you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return ]
If the computer is dirty inside use a can, or two of compressed air for computers, and clean it out.
You may also need Q-tips to break the outside 'crust', by stirring it around. Then the compressed air can remove it better.
[ You may wish to don a dust mask, and protective eye-wear ]
(Especially good for where the fan blades, meet the center hub of the fan; Edges of fan blades, and other areas )
Insert the plastic straw provided on the side of the can, into the nozzle at the top of the can.
Break the plastic lock tab off of the top of the nozzle.
Start at the top left, or right inside corner.
Spray air as a professional paint sprayer would.
Squeeze the trigger in all the way as you start, let go when you reach the other side.
Drop down a space, and spray air across again. Keep dropping down in rows, and spraying across until you reach the Processor Fan.
The Processor Fan sits on top of a finned Heatsink. The Heatsink sits on top of the Processor.
(The construction of the Heatsink is basically a small plate of metal, with tall, thin fins protruding from it.
The plate of metal absorbs heat from whatever object it is placed against, { Processor in this case}, and the tall, thin fins absorb heat from the plate of metal.
The tall, thin fins then radiate the heat away. The air flow from the Processor Fan, goes in-between the fins, and around the fins, and helps to carry heat away from the fins )
Use special care to ensure that the fan is clean, and the Heatsink.
However note that only use Short Bursts of air, when cleaning the Processor Fan.
(Q-tips come in handy here)
The Processor Fan is only designed to spin so fast. Spinning it faster than it was designed for (Long blasts of air), may shorten the life of the fan's bearings.
Keep cleaning until you reach the bottom of the computer case. Tilt the top of the case towards you, clean the bottom of the case.
The Power Supply is inside the computer case at the Top/Back.
Clean through the ventilation holes of the Power Supply's case, as best as you can.
Go around to the back, and clean the Fan, and surrounding cage. (Shroud)
Come back to the inside once more, and give it one last 'dust off'.
Also after time 'corrosion' develops on the contact pins, of the Ram Memory modules.
The Ram Memory module/s should be removed, and a pencil eraser used to clean the contact pins.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
The Body of the ram memory module ('Stick'), is everywhere but the contact pins, at the bottom.
A ram memory module should be handled by the Body.
The Body is coated with a see-through protective plastic.
Refrain from touching the gold plated contact pins.
If an eraser is used on the end of a pencil, and not a solid eraser, refrain from letting the metal band touch the contact pins.
Rub EACH contact pin. There are 184 pins. 92 on each side.
(Doesn't take long)
After cleaning use air to remove the eraser dust. You can use air from a can of compressed air, or air from your mouth will be sufficient.
Reinstall the Ram Memory module/s.
C2) Power Supply
Could have a weak voltage power rail.
LED lights could light, and maybe fans spin, but Not enough power to turn the Processor on.
A) IF all of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 watts of power. Just depends on what Processor it is.
There are 3 main voltages produced by the Power Supply.
A) 3.3 Volts (DC) { Orange wires}
B) 5 Volts (DC) { Red wires}
C) 12 Volts (DC) { Yellow wires }
{ALL Black wires are Ground wires }
Test the Voltages to see if the Power Supply is good, (Multimeter), or use a KNOWN to be good, compatible power supply for a test unit.
[Sometimes it's found that there may be an unused desktop computer around, that may have a working power supply, and it may work in the computer you are testing ]
If no spare power supply is available, purchase an economical $30 unit for a replacement.
{ATX}
If you just want your information off of the harddrive, install it into an economical external enclosure, and remove your data.
[ It is an IDE (PATA) harddrive. It is desktop size, which is 3 and 1/2 inches across in width. You need an IDE (PATA) 3.5 external enclosure.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779 ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 14, 2012 | E-Machines T2240 PC Desktop
Display driver sttoped reponsing and has recovered successfully
test all leads from motherboard to hard drive make sure they are securely seated with no dust built up or in the connections
might be a dusty graphics card socket
you might remove the graphics card make sure sure its clean and dust free
restart your computer and reinstall it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrative tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers
if you don
Oct 20, 2011 | Biostar G31-M7 TE Motherboard
2 short 1 long x 5 beeps no display, no yellow light
1st unplug your power cable in monitor than see what's masage sow there if no masage than a monitor problem and if you see masage than please chack ram
Sep 05, 2011 | HP Media Center m7060n PC Desktop
I start my computer up and i get 3 beeps and a black screen!
Three beep usually mean there is a ram issue. The computer is not passing the post. To resolve this issue I would first try to reseat the ram. Basiclly you will remove the Ram and place it back in the same slot. If this fail, place the ram in another slot.
Jul 11, 2011 | Computers & Internet
ET1161-07 onboard Video gone bad. I tried a Gforce 8800GS 384mb card, that works, and I have no video, 1 long beep that never stops. Ican't get into the bios with the onboard video or the new video and...
Hi.
One continuous beep means that you probably have not put the graphics card in the PCI express slot or there is a short somewhere in the system.
Follow these steps to try and resolve the problem:
Remove the power cord and the video lead from the back of the machine and then remove the side panel to reveal the motherboard.
Remove the graphics card and take a look at the PCI Express slot for dust. If you see any dust get a clean, dry paintbrush and clean the dust from the slot and then blow on the slot to remove the rest of it.
Next look at the brass contacts on the graphics card and clean then. Re-seat the card making sure that it is fully pushed down in the slot.
Check that any other cards you have installed in the machine are seated properly.
Without putting the side panel back on, connect both the video lead and the power cord and turn it on. DON'T TOUCH ANYTHING INSIDE THE COMPUTER!!!
If the computer boots up turn it back off and put the side panel back on. If not then please post back telling me what the computer is doing.
Good luck.
Jun 07, 2011 | eMachines ET1161-07 Desktop PC
I have a Hanns.g 28 inch monitor it display no input singal video card is a GF 9600 GSO the monitor will power on but still display no input singal
Your GeForce 9600GSO may be malfunctioning. I suggest you unplug it, remove it, clean out any dust that may be in the PCI-Express slot (you can use a vacuum cleaner), then re-insert the graphics card and plug it back into your monitor. If this doesn't work then you'll need to either try another PCI-Express graphics card in the PC just to test whether it is:
1) The graphics card.
2) The other components such as mainboard, cpu, ram, etc.
If your don't have a spare graphics card then I suggest you take your PC down to tyour local PC shop and have a technician take diagnose the damage.
Apr 16, 2011 | Hannspree HW191D LCD Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
