Question about HP 2133 Mini-Note Notebook
Sticking key and the other key are not working
    Sergeant:
  • HP Expert
  • 427 Answers
Posted on Apr 17, 2013
Why doesn't key turn in ignition switch?
Sharply turn steering wheel back and forth while trying ignition, this may loosen the lock detente pin enough to work.
If key is stuck, under the steering wheel there is a button or what looks like a button , stick a key in the little indention and the button falls out ( no force required) and then stick a long firm wire straight up and you will hear a faint click and the key should come out. I used a long match stick like the ones you would light a fireplace with. Della press the helpful button
Jan 21, 2016 | 1995 Chevrolet Blazer
96 ply breeze ignition key sticks
It could be a couple of things. 1) try lubricating the key and key lock in column.2 if your steering wheel is turned and has pressure on it, relieve the pressure by turning the wheel at the same time removing the key.. If these don't work, add some info on the problem. Is it auto or stick?
Apr 01, 2013 | 1996 Plymouth Breeze
It is stuck and no keys will work. It shows small "degree" and "0" only. It will not shut off.
Try taking out the batteries. If that doesn't work it may be that your key pad is sticking. You may need to take apart the calculator and clean the keys so they don't stick. Good luck!
Mar 11, 2010 | Texas Instruments TI-30XA Calculator
Keys sticking. The keys at both ends are sticking or won't go all the way up and strike the paper.
Try trickling some White Spirit into the typebar slots and working the keys repeatedly.
Jan 10, 2010 | Olivetti Linea 198 Typewriter
I have the same problem with the key being stuck in the ignition
just repaired my girlfriend one, and like you said the button keeps sticking, cuz their is a small rod, that got loose, you need to remove all the panel around the stick, most are just clip-on, might need, to force them, and the last big peace, as 6 screws, and from their, look under the stick, on the passenger side you'll see the switch, , just push back the rod in place and voila!, I just did it,
Oct 06, 2009 | 2006 Pontiac G5
How do I fix an ignition problem
At first my key would stick in the ignition..then after a little while it could be removed...some times I had to wiggle the shifter.now it does not work and the key is stuck...Thank you all...Ray from MI
Apr 25, 2009 | 2001 Pontiac Aztek
Key sticks in ignition
I would say your ignition cylinder is worn out. get it replaced now, while the key still works. If you wait until it stops working all together, they will charge double because it will have to be cut off of the steering column instead of easily sliding it out. I wouldnt think the lights and door locks are related, just a bad coincedence.
Jan 20, 2009 | 2002 Toyota Camry
Lost bluetooth stick for my diNovo Edge
You might beable to buy a replacement key from logitech, and no any stick wont work, it has to be the one designed for use with the dinovo.
Jul 08, 2008 | Logitech diNovo Edge 9676850403 Keyboard
HP 2133 Mini-Note Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
