Question about AviStart 5303 2-Way Security / Remote Start System
2005 chevy aveo wiring diagram to install remote starter avital 4000xl
4 Suggested Answers
  • 34 Answers
SOURCE: im about to install a
the one you need to use is the wire that shows a 12volt power in cranking posision
Posted on Jan 09, 2009
jpk528
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
  • 139 Answers
SOURCE: need wire diagram for avital 5103
You can download a copy of the installation manual from this link:
Avital 5103 installation manual
Posted on Sep 25, 2012
Need to program additional fob to Avistart 4111
Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
Feb 08, 2014 | 4111 4111L Remote Car Starter
Avital 4003 with xpresskit xk09 install in a 2006 chevy silverado 2500HD gas engine. how to wire all the wires to get it working with the factory key fob.
disconnect battery remove the engine mount bolts jack up support from top remove starter and flywheel inspection cover remove mounting bolts for engine pan lower and remove oil pump suction pipe should come out then. don't forget to drain engine oil first.
Sep 12, 2013 | 4003L Avital 4003 Remote Start Module...
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
How to remove starter from a 2005 chevy aveo
Please don't forget to rate....thank you:
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle safely.
  3. Disconnect the starter electrical harness.
  4. Remove the starter ground bolt.
  5. Support the starter and remove the bolts.
  6. Remove the starter from the vehicle.
73fcc2b.gif The location of the starter
To install:
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Install the starter. Tighten the mounting bolts to 32 ft. lbs. (43 Nm) on 2005 models. Tighten the solenoid nut to 11 ft. lbs. (15 Nm).
  3. Install the ground bolt and tighten to 30 ft. lbs. (41 Nm).
  4. Connect the starter electrical harness.
  5. Connect the negative battery cable.
May 04, 2010 | 2005 Chevrolet Aveo
I got avital remote control starter and the car cant star
What kind of vehicle? And did you wire it into the alarm? If you reply with a vehicle year and model I can give you the wiring diagram.
Jan 13, 2010 | Car Audio & Video
AviStart 5303 2-Way Security / Remote Start System Logo
114 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
Philip Armitage
 Mikey
Mikey
The Los Man
Level 1 Expert
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
