Question about Compaq Presario 700 470024-192 Notebook
Screen won't come in but the computer comes on
My mother has a Compaq Presario 700 (laptop). She cleaned her computer screen and now she can turn it on, you can hear it coming on and everything but the screen never comes in. Is it damaged?
  • John Hong
    John Hong May 11, 2010
    How did she clean it? Did she use a liquid? If so it may have run inside and it shorting out something. If she is lucky it MIGHT work again after it dries, in the meanwhile she should unplug it, remove the battery and put it in a dry location for a week.
U just need to restart ur lap n press f8 or f4 it will give u list be 4 booting in det u have to select last boot knwon good confugration it will work if not den u need to restor ur system
Posted on Jan 16, 2009
Compaq presario 700 monitor off
Hi
Maybe, depending on the problem. Laptop monitor problems fall into three categories. 1. Screen electronics or lamp. 2. Inverter. 3. Laptop video chip. I've been repairing latops ever since they arrived on the market. First connect an external monitor to the laptop - this will show you whether or not the laptop motherboard is working correctly. If it is then you'll need to replace either the screen or the inverter. So as not to waste alot of money, at this point I would suugest going to a reputable repair person or check my website www.micromendllc.com
Jun 05, 2010 | Compaq Presario 700 470024-192 Notebook
I turn it on i get white blank screen. same when external is hooked up
Seems it is the Video card which has gone bad, If in case your system shows Compaq on your screen, os in that case need to install windows in the system again.But if it does not , Please get your system's Video card again.
May 25, 2009 | Compaq Presario 700 470024-192 Notebook
Blank Screen on Start Up. (Compaq Presario 700)
Unplug all external devices and then check. Go to BIOS and restore it to factory defaults
Mar 03, 2009 | Compaq Presario 700 470024-192 Notebook
Compact presario v5000
remove your RAM from their slot then insert it again, hopefully this may solve your problem
Oct 16, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 Screen works but multicolored & hard to see things.
If you have a short or loose cable in the LCD assembly, it would be a good idea to have a local tech check it out, specially if you "fix" it by pressing or moving the screen around.
Sep 27, 2008 | Compaq Presario 700US Notebook
Compaq presario 700 no picture
u just try for the buttons in the down of ur pc or may be at the sides..............just press it an enter the menu for adjustments...........there will be an option called DEGUASS just press it once.......ur pc's screen will shake for a while and then stops.........then u will get an clear display.or press F8 and change the settings.
Sep 08, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 laptop problem
Most of the time blue screens like that indicate hardware issues. You may try replacing the memory. I wouldn't put too much money into something of that age, though.
May 23, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario 700 Black screen
There might be several reasons, hardware nor software/operating system, but most probably from the hardware. Can be the graphic card (if you can notice the hard disk work well - from the sound), can be the hard disk, or even the mother board. We have to go through the symptom.
Since it is still new, the best solution is back to the seller for guarantee.
Feb 27, 2008 | Compaq Presario 700 470024-192 Notebook
Presario 700 very dim screen
i would say its the inverter. worst case senario it would be your lcd screen.
Oct 30, 2007 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
