Mac cannot recognize my HD-PXTU2
HD-PXTU2 portable hard disc
rulds2008
  • 3866 Answers
SOURCE: my portable hard drive is not recognized by my Mac G4 power book
You have to run mac tools that is on that hard drive prior to plugging it in.
Posted on Jun 14, 2009
  • 101 Answers
SOURCE: my WD 250GB passport portable hard drive is not recognized
If your system detects the connected device that is a good start. Was the drive formatted for another operating system? Certainly try the drive on another system and/or another drive on your system.
Posted on Aug 26, 2009
bob_computer
  • 3153 Answers
SOURCE: my mac won't recognize my wd hd anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Aug 31, 2009
lock123
  • 6831 Answers
SOURCE: WD portable hard drives not recognized
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
bronk50
  • 27725 Answers
SOURCE: i forgot my buffalo HD-PXTU2 harddisk password
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
hope this helps
Posted on Sep 28, 2012
Formatting buffalo ministation stealth for mac
Probably the software could not recognize or support the disk type/model
Dec 18, 2013 | Buffalo Technology 1tb Ministation Stealth...
Can i take my portable hard drive from my hp desktop and connect it to a mac?
Hello Leean,
You can take the portable hard drive from your HP Desktop. But when you connect your hard drive in Mac machine it will not recognize it. Because the hard have NTFS partition and the Mac operating system will only recognize HFS & HFS+ partition.
You can only use the NTFS partitioned hard drive on Mac machine if it have Parallels OS. Parallels allow you to connect your NTFS partitioned hard drive in mac machine.
Oct 13, 2011 | Computers & Internet
I'm having problems with my buffalo mini station 1tb HD-PXTU2. It cannot copy files that are 4gb and higher. After trying to copy it, an error message will appear andf state that the disc has no spac left...
From My Computer the External Hard Drive can be reformatted.
I beleive the format is called TFMS, this allows a larger than 4Gb single entry to be inputted. It is probably formatted for FAT32 which is limited to 4Gb units
Nov 14, 2010 | Computers & Internet
2 issues...one won't read one is locked
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
May 13, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
PC doesn't recognize Passport after Mac use
you must choose the format you wanna run on your hdd.mac and pc aren't the same.
Apr 16, 2010 | Western Digital WD Passport 250GB Portable...
My WD 250GB passport portable hard drive is not recognized
Aug 26, 2009 | Western Digital WD Passport 250GB Portable...
Mac 10.4.11 Acom data hd/ the hard drive does not show on desktop or file menu. does show in the disk utility.
Is this working before with this Mac Tiger? Or is this the first time you're connecting this HD to your computer?
If first time, there's a possibility that the HD has different file format. It should be formatted as Mac OSX (Journaled) in order for the Mac to recognize it.
If this is working before with this computer, check the status of the HD. Most HDs that could only be detected under the Disk Utility needs a reformat.
IMPORTANT: Formatting the HD would erase all the files inside of it. You may need to bring your HD to the nearest Data Recovery Center to retrieve the files inside and then you may now reformat the HD.
Have a great day!
Jun 30, 2009 | Acom (HD120FE) Hard Drive
My portable hard drive is not recognized by my Mac G4 power book
Jun 14, 2009 | Western Digital WD Passport 250GB Portable...
Secure HD Login Problem
in applications there is one called utilities in this is one called disc utilities see if the drive shows up ? if it does try repairing permissions and verifying the disc.
Aug 28, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
