Question about Canon imageRUNNER 5000 Copier
Canon ir 5000 erorr E 000070 - 0000 How to fix it
Not on display
Posted on Mar 01, 2013
3 Suggested Answers
SOURCE: canon ir 5000 erorr E 000004 - 0000
.it is an heater lamp problem
or
thermostat is a problem
Posted on Jun 02, 2010
lahen01
  • 63 Answers
SOURCE: Canon ir 5000 erorr E
in this order press additional functions, 2 and 8 simultaneously, additional functions. This takes you into service mode. Then press copier, function, clear, error, then ok. turn machine off with the side power switch and back on.
Posted on May 24, 2011
Canon ir 2202 erorr cod e002-0000
see if this link helps
http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
Mar 15, 2016 | Canon Office Equipment & Supplies
Erorr 000602-0102 ir 5070
Turn power switch on right rear of machine off. Hold down the 1 and 9 keys while turning the power switch to the on position. There will be a cascading cursor run from the top of the screen to the bottom. May take a while to scan HDD. when it is finished turn off and then on again.
Jun 13, 2012 | Canon imageRUNNER 5570 Copier
Canon ir 5000 erorr E 000004 - 0000 How to fix it ?
May 24, 2011 | Canon imageRUNNER 5000 Copier
I found in canon ir 2018 erorr E 007 what this mean and what the solution ?
it is mean the fixing film was broken/torn.
you must replace a new.
be careful when you replace it.
May 17, 2011 | Canon iR 2016i Black and White Copier
Code e000014 canon ir runner 5000 problem moter ripayer solutions
If you are a technical person
Check the following
(i) Are the connectors of the fixing motor connected?
If not,Connect the connectors.
if yes
(ii)Replace the fixing motor.
Does this solve your problem
If not
(iii)Check the wiring; if normal, replace the DC controller PCB.
I'm damn sure your problem will be solved.
You can take my word.
Apr 16, 2011 | Canon imageRUNNER 5000 Copier
I can't using my canon MP510 because i am cod erorr 5000.help me
I see the service manual the 5000 eror is not exist,sure is not error 5100 or 5C00 ?
Apr 05, 2011 | Canon PIXMA MP510 All-In-One InkJet...
or
Jun 02, 2010 | Canon imageRUNNER 5000 Copier
ImageRUNNER 5000 Copier: I own a Ir 5000 and i just started getting "tire t...
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
May 17, 2010 | Canon imageRUNNER 5000 Copier
ImageRUNNER 5000 Copier: how to set a password for ir 5000...
under User mode ( round button with * ), choose ID management. The rest is yust the reading from panel.
Pls. rate
May 05, 2010 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
120 people viewed this question
old marine
old marine
