Question about Radio Shack Pro-95 Handheld Scanner
Scanning problem I have all of the trunked frequencies programmed into the scanner and they all work in manual mode, but when I put the scanner in scan mode it will not pick up and broadcast the frequencies.
    Novelist:
  • 114 Answers
I HAD THE SAME PROBLEM AND HAD TO GO TO ONE CHANNEL AT ATIME IN MANUAL AND HIT THE PROGRAM BUTTON TO RESET IT TO MEMEORY. YOU CAN TELL IF IT IS THE PROBLEM IF YOUR SCREEN READS "ALL CHANNELS LOCKED-OUT"
Posted on Jun 22, 2007
  • Joseph Reckinger
    Joseph Reckinger Jun 22, 2007
    MINE DID IT BECAUSE I HAD LEFT THE BATTERIES OUT FOR A WEEK.
Having problem programming Pro-94, is there a simpler book or read than the manual. It says you must load in logical channel order. how do I determine this??? Also am I correct in that you can only load...
put your scanner in manual mode.and then go to program mode and program your frequencies into your scanner.try that and see if that works.....if not it could be a problem in your Radio....
Feb 22, 2011 | Radio Shack Pro-94 Scanner
How do you start to program a bct8 800 mz scanner
Programming conventional frequencies into the scanner's PRIVATE bank is simple, but programming trunking systems is a detailed process that will take some research and probably some practice. The best instructions for both types of programming are found in the factory operating manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BCT8om.pdf
For a comprehensive database of active frequencies and trunking systems in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Jan 11, 2011 | Uniden BCT8 Base Scanner
Scanner locks on tower frequency
If you are using a trunking system, then it sounds like you just have it set for "FM" mode, instead of "MO" Motorola trunking. You will have to use your owners manual to see how to set up a trunking system by putting the control channel (tower) frequencies in a special mode, then it will work if it is a PRO 96, PRO 106, etc.
Aug 10, 2010 | Uniden Radio Communications
How to program a radio shack pro 163 police scanner
The 163 is a trunking scanner, so programming instructions are long and detailed, and they vary for each type of trunking system. Programming instructions are best explained in the factory operating manual. If you don't already have it, you can download/print the manual here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-163-164-OWNERS%20MANUAL_2000164_PM_EN.pdf
You may also want to join a users group for the 163. Check Yahoo or just Google PRO-163.
For a comprehensive database of active frequencies and systems in your area, visit:
The site also has information that explains the workings of trunking systems, links to users groups, and a lot of other useful scanning information.
Bill B
Jul 04, 2010 | Radio Shack Pro-97 Handheld Scanner
800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
How to program the frequencies on a uniden bearcat 50 channel 800 mhz radio scanner?
To program the majority of non-trunking Bearcat scanners,\:
- Power the scanner ON
- Press MANUAL to stop scanning
- Enter the channel # to program followed by MANUAL (OR just press MANUAL repeatedly to advance to the desired channel).
- Enter the desired frequency, including the decimal point.
- Press E (ENTER)
If these steps don't work with your scanner, please provide your model number and I'll get back to you with specifics.
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
When scanning the radio resumes before end of transmission
The manual states that the scanning will halt whenever the squelch is broken by a transmission, just as expected. When the transmission is complete, the radio continues scanning. This makes hearing any reply nearly imposible to monitor - and is the problem I believe you are describing.
Page 37 of the manual says that a 2 second delay can be assigned to a frequency whenever the radio has paused on a channel. Simply press the DELAY key on the scanner to assign the delay to the channel. If there is no additional transmission within 2 seconds, scanning will resume.
Below is a copy of the manual to reference or print if you can't find yours (you'll need a free program called "Adobe Reader" found at www.adobe.com to view or print this manual).
http://www.uniden.com/pdf/bc898tom.pdf
I hope this helps!
Oct 30, 2009 | Uniden BC898T Base Scanner
Trunking frequencies
Did you initialize your scanner? If you did, then you also deleted your trunking banks (1-9). These are the banks that store the channels that were inputted by you. The scanner will display "All channels locked out," when all of these banks are empty. You may have to put the frequencies in again. I suggest using win97. There is a 30day trial. This is the only program that I know of that will work with this scanner.
The pre-programmed channels should still be there. If you press and hold the scan button for a couple of seconds you should see the signal stalker running.
Good luck.
May 02, 2008 | Radio Shack Pro-97 Handheld Scanner
Edacs frequencies
Are you getting talkgroup ID's? If not, you're probably monitoring the EDACS system in conventional mode rather than trunking. When the scanner hears those beeps, it's supposed to go back to monitoring the control channel if you're in either trunking mode (search or scan). This also happens if the CC isn't coming in very well. If you're not in trunking mode, read the manual to find out more about programming and monitoring trunked systems. If you are in trunking mode and receiving ID's, the unit is probably malfunctioning.
Sep 23, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-95 Handheld Scanner Logo
128 people viewed this question
Top Radio Shack Radio Communications Experts
xxxxxx xxx
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
