Question about LG LHD45EL Dehumidifier
Prem-i-air Model EH1104. . Any idea what sensor it uses?
When sensor shorted out machine works and extracts water. Otherwise it doesn't. I need to know what humidity sensor chip would be suitable
4 Suggested Answers
  • 16 Answers
SOURCE: In the last week or so the top of the unit is very
I think you may have leak on your system, please have it checked over by a qualified engineer!
Posted on Nov 13, 2009
heatman101
  • 43501 Answers
SOURCE: it runs, but extracts no humidity from the room.
Here is a tip that I wrote that will help you...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Posted on Apr 16, 2010
joeguest2
  • 2080 Answers
SOURCE: Due to the recent rains and flooding our basement
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. Also make sure that the basement is warm enough. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work. Add heat to the basement if necessary to improve the unit's performance.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Hope that was helpful. Thank you very much and good luck.
Joe.
Posted on May 23, 2011
Dehumidifier still runs, blows air, various controls all seem to respond. Just doesn't dehumidify. If I need to take it in for repair, can you recommend someone in Northern VA area? Thanks.
It may not need repair as, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(no LED screen), turn the humidity extraction knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot & solve the problem without have to make any repairs.
Thanks for choosing FixYa.
Aug 19, 2011 | Soleus Dehumidifiers
New Whirlpool gold dehumidifier last summer. Used since then. It still runs (fan) but no water is being taken from the air. I clean the filters, looked at coils, they are like brand new. I hate to give up,...
Kim, it may simply be a case of the humidity extraction level being set to HIGH. Lower it to 35%. If it's an analog unit (No LED Display) turn the humidity extraction knob to Maximum. More often than not, this will solve the problem. If it doesn't the humidity sensor may need to be replaced.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Runs constantly and doesn't remove much water.
John, there are 5 basic, yet solvable sfor what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. Isf you have an analog unit
turn the humidity extraction level knob to Maximum.
problem.
I hope this helps your to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Whirlpool AD25BBK Dehumidifier
My Kenmore 50 Pint dehumidifier doesn't seem to be collecting any moisture in the bucket. Just wondering if it may need maintenance? Thanks
If it hasn't received routine maintenance recently, now is a good time.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. In you have an analog unit
set the humidity extraction knob on Maximum.
problem.
I hope the above helped you to troubleshoot and solve the problem. Please let me know and thanks for choosing FixYa.
Aug 10, 2011 | Kenmore 54501 Dehumidifier
Model BHD-301-D Will run from 1 min to 4min then shut off. I've tried all setting from 3 to top does same thing. I have a wet basement so it should stay on all the time. If I unplug it and then plug it...
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1, 2. & 5.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a mechanical unit,
5. Ambient air temperature at floor level is between 40 - 65 degrees.
problem.
I hope this helps you to trouble shoot and solve the problem. Thanks for choosing FixYa.
Aug 06, 2011 | Comfort-Aire BHD-301 Dehumidifier
I bought this unit on 13 August 2009. The unit runs, the bucket is in place, the filter is clean, but it doesn't remove any moisture from the air. The unit is in the basement in the exact same place it...
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
level
problem.
I hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 29, 2011 | LG Dehumidifiers
The unit runs continuously but doesn't collect any water.
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit (No LED Screen) turn the humidity extraction knob to Maximum.
level
problem.
Hope this helps you to troubleshoot and solve the problem.
Jul 06, 2011 | Fedders A7DH65B2A Dehumidifier
Everything works, except the appliance doesn't absorb nor eliminate the humidity; the pan doesn't fill up and the hose doesn't spew out any water. The electronics seem fine in that the power...
As I tell all the folks who report the same problem you have. There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 and 2.
in basement applications level. Raising the unit up off the floor,
problem.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 24, 2011 | Kenmore Dehumidifiers
It runs but does not extract water
Susan, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35% If you have a manually
controlled model, set the humidity extraction knob to Maximum..
level
in basement applications . Raising the unit up off the floor,
problem.
I hope this helps you to troubleshoot & solve the problem.
Jun 22, 2011 | Maytag M7DH45B2A Dehumidifier
Where to go for spare parts for dh250r need circuit board for compressor
Glenn, here is a link to Delonghi Parts and Accessories website. You can order parts there if you have the Part Number. Or you can call Delonghi at 800-865-6330.
Hope this helps you find the part your need.
Apr 28, 2011 | DeLonghi DH100P Dehumidifier
LG LHD45EL Dehumidifier Logo
54 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
