Question about Optoma RD50 50" Rear Projection HDTV-Ready Television
My Optoma HDTV Model RD50 needs replacement of its internal lamp. Which model lamp is the correct one and how much does the lamp cost? Regards - Lee
Call Optoma technical support listed on the optomatv website. They will ask for the set serial number. Based on the serial number, they will tell you which replacement lamp is the correct model for your TV. (I found this out after ordering the wrong replacement lamp based simply on the model number of my TV and finding that it did not fit.)
Posted on Apr 02, 2009
I have a optoma rd65 when on it makes a loud humming noise
You most likely have a failing color wheel. This is a known problem in the RD65. If you search on EBay for an RD50 color wheel it is the same one that goes in the RD65. They are roughly $150 depending on who you purchase from. They can be user replaced if you are handy with tools. The bearings wear out and this causes the humming you are hearing. Optoma RD50 color wheel replacement AVS Home Theater Discussions And...
Sep 23, 2014 | Optoma RD65 65" Rear Projection HDTV
Calibrations for optima rd50
sorry but I cannot help you, this site is undergoing a restructure--send an email to staff@Fixya.com attention to SCOTT.
I hope you get the answer you need.
Regards, SD TECH
Oct 20, 2011 | Optoma RD50 50" Rear Projection HDTV-Ready...
I replaced my RD50's lamp recently and everything works perfectly, but the notice telling me that it is time to replace my light continues to display every time I turn the set on. There is probably a way...
There should be a reset lamp function in the service section of the menu. If there isn't, there is a way to do it by pushing and holding a sequence of buttons on the tv or remote. It varys from model to model. Check your manaul to see what the correct proceedure would be for your model.
Feb 09, 2010 | Optoma RD50 Television
Need a new lamp for RD50 tv.
Good Day, jo;
When getting a new lamp it is less expensive and faster to purchase the needed lamp from the manufacture of TV. (Make sure you have model number at hand). They will send lamp directly to your home, the lamp will have enclosed instructions on replacement and any special tools you may require. It is very simple and will only take about 15 minutes at the most to replace.
Good Luck, big IRISH.
Jul 15, 2008 | Optoma Televison & Video
Optoma TV light Engine or Optical Engine Replacement
Technical Service Corp 888-942-2929 is where you can purchase an optical engine, I inquired for my RD 65. The part cost over $900, not quite worth it.
Hope this helps
Apr 15, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Lamp light on picture off
You might try unplugging the set for maybe 20 mins. to see if that might help in resetting the internals. Good luck!
Mar 25, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Optoma RD50 Lamp Issues
replace the fuse thats on the little board beside the new lamp. that will reset the buld to new. I understand that the fuse will blow right after a new lamp is installed. It will reset the counter to 0.
Hope this helps
Ron
Dec 30, 2007 | Optoma RD50 50" Rear Projection HDTV-Ready...
After lamp replacement
Sounds like the plug is not making a good connection needs to be seated better.
Dec 10, 2007 | Optoma RD65 65" Rear Projection HDTV
Optoma RD50 Picture Flashing ghost images
Hello! Just a little additional info if you will on what might to expect. This is according to the repairman where my tv is still in the shop after almost 2 wks because of the need for parts: other than the lamp the only place to get other parts (ballast and color wheel) is from Optoma and if yu need the color wheel you will have to purchase the entire assembly ($999.99) because they do not sell it separately. If anyone knows differently please let me know for I am between a rock (not really) and a hard place.
Dec 04, 2007 | Optoma RD50 50" Rear Projection HDTV-Ready...
Optoma RD50 50" Rear Projection HDTV-Ready Television Logo
279 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
