Question about Water Heaters
How to reset Pro CT25 boiler - Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
My ariston boiler is not working it just shows A 01 have reset but still nothing any ideas?
Basic checks:-
water pressure in boiler
gas supply on
Turn boiler on then:-
does the fan come on - u can hear this at the top of boiler
does the gas valve click on
has there been a burning smell near the lower front [check the pcb]
check the co-axial flue is ok with no gaps between inner & outer [rare but not unknown]
If it's a condensating boiler check the condensate outlet tube for ice blockage especially in current weather
Dec 27, 2009 | Water Heaters
I HAVE A HALSTEAD ACER HIGH BOILER AND IT IT IS SAYING LOCK OUT ON THE BOILER WHAT CAN I DO TO FIX IT
The overload button is on the left underside of the unit. There is a finger sized hol and the button is in there. Once you have reseet the button you will also have to reset the boiler by using the switch on the control panel (furhtest left switch).
Dec 03, 2009 | Water Heaters
My dad has a valliant boiler VP4 ZE15 IT IS AROUND 3 YEARS OLD IT ISNOT IGNITING I HAVE TURNED PRESSURE UP AND HELD THE BUTTON IN FOR A MINUTE. i CANNOT FIND WHWERE THE RESET BUTTON IS TO TRY THIS PLEASE...
Turn the power off at the wall , wait 60 seconds and the boiler will automatically reset.
Modern boilers are complex re safety and the boiler will only start if the exhaust fan is running and is up to speed .
The vacuum caused by the fan trips a switch and allows ignition to continue
If the pilot light does not come on it does not warm up the thermocouple which turns on the main gas valve.
If you go to the Valliant website they will supply you with a user guide
Sep 28, 2009 | Water Heaters
Vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Mar 14, 2009 | Water Heaters
Water Heaters Logo
396 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
