Question about Zyxel Computers & Internet
ZYXEL NBG-418N WIRELESS ROUTER - Zyxel Computers & Internet
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Posted on Apr 30, 2008
rahul26485
  • 611 Answers
SOURCE: connecting using wireless
because of zyxel support only zyxel product only
Posted on Jun 13, 2008
kakee
  • 1268 Answers
SOURCE: Low signal after firmware update
It is recommended to hard reset the router every after firmware update. Look for the reset button normally at the back of the router. Press and hold it down for 20 seconds then release, then unplug the power for about 30 seconds then plug it back in. That should fix it.
Posted on Oct 27, 2008
SOURCE: installing wireless router
I got a zyxel wireless router and was able to plug it into my eircom connection without much hassle.
Step1 - configure the wireless router.
This involves connecting the ethernet cable from the zyxel to your computer. Once your ethernet cable is connected to your pc, you can setup the router by opening your favourite browser and typing in this http://192.168.1.1
That will open a "welcome to zyxel setup" page and you need to enter in a password to get in...check the documentation that came with the zyxel but I think the default is
username: admin
pass: 1234
STEP 2
Once you get past the login stage, you are effectively connected to the zyxel control panel where you can configure your wireless and broadband settings. I used the wizard which steps you througn each step....including setting a nickname for your wireless router and the security phrase.
On the advanced settings page, here are the settings for eircom (under the broadband->network option):
Username: eircom
Password:
broadband1
Encapsulation: PPPoE
Multiplexing:
LLC Based
VPI: 8
VCI:
35
Primary DNS: 213.94.190.194 *
Secondary DNS: 213.94.190.236 *
* I didn't need to set those...I simply selected "detect IP address automatically".
I hope that helps others. I bought a second hand zyxel on ebay and it came this morning without a manual, so I stumbled my way through it with the help of google. My zyxel was a p-600 so I'm not sure if the control panel will vary with other models...the key thing is using http://192.168.1.1 in your browser, with your ethernet cable attached between your router and computer, to "get into" the router in the first place, once there, you should be able to walk through the setup without too much grief.
This is my first wireless router, so I can't say whether they make great routers or not - I've nothing to compare it to - but, it does exactly what it says on the tin for me.
cheers
Gus
Posted on Nov 14, 2008
rcw1962
  • 2571 Answers
SOURCE: How do you forward ports
I could only find info for the NBG-415n
Look here http://portforward.com/english/routers/port_forwarding/ZyXEL/NBG-415N/NBG-415Nindex.htm
Posted on Aug 20, 2010
I need help putting a password on my wireless connection through my router. How do I do this?
1. Connect your internet to a computer
2. Go to internet browser -> type in http://192.168.1.1 in the address bar
3. You should see the router login page. Type in default user name and password
username : admin
password: 1234
4. Follow a setup wizard to put your device name and wifi password.
I have attached the manual link below:
ftp://ftp2.zyxel.com/NBG-416N/quick_start_guide/NBG-416N_1.pdf
hope this help.
Aug 06, 2014 | Zyxel Computers & Internet
How to recover forgoting password?
The most reliable way is to reset the device, by pressing the recessed RESET button on the back of the device. It's quite small, but an unfolded paperclip should do the job. Once reset, the device is now back to all factory settings, and will be set to username of default and password of admin. In some cases, this can vary a bit. There is an excellent page (see link below) all about resetting this device at Router Defaults dot com's web page.
router defaults com
Jan 26, 2014 | Zyxel NBG-418N 300Mbps Wireless N Router...
How can i sersure my zyxel router
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 26, 2012 | Zyxel Computers & Internet
How to set password to avoid others using my wireless setup?
Enhanced Security with WEP, WPA/WPA2 and Firewall The NBG-417N supports the latest, most secured WPA2 wireless encryption with its one-button encryption setup. It also supports commonly used 64/128-bit WEP, WPA encryptions. It provides stringent protection for wireless transmissions. In addition, the NBG-417N is equipped with firewall features including NAT, Stateful Packet Inspection (SPI), Denial-of-Service (DoS) and VPN Passthrough (IPSec, PPTP, L2TP) to prevent attacks coming from the Internet.
Feb 16, 2011 | Zyxel NBG-417N Wireless Router
NBG-419N can not connect to the internet thru router?
Have you connected your Zyxel to your cable/DSL modem? Is your access problem issue with Wireless computers? The first thing you must do with a new router is to set it up, using a CAT-5 cable connected to the router. Connect it to http://192.168.1.1 and proceed through the setup items, after logging in to the router. One of the more important items, Security, must be set up by choosing your network name (SSID) and security passwords --- I prefer using the WEP-PSK[TKIP] for its simplicity. You will need the passcode you choose whemn you try to access the router wirelessly, once this is set up. Not too much access unless this is done. Use this as a guide:
http://www.zyxel.com/guidemo/NBG419N/local/networkmap.html
Nov 10, 2009 | Zyxel NBG-415N Router
Got a ZyXEL NBG334W wireless cable router and trying to set up on my computer, everytime it says cant find dns server.
1 Install your software that came for NBG wireless cable router CARD DRIVERS.
2 Now INSERT your NBG wireless cable router CARD in your PC
3 Window will say found new hardware.
4 Now Insert your router DISK and open your Internet Explorer
5 You should have your default ROUTER IP ADDRESS
YOU MIGHT HAVE TO SIGN IN OR PROVIDE PASSWORD
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
775 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
