Is there a battery in this thing - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
What make and model is "this thing"?
Posted on Dec 04, 2012
My 2000 mercury mountaineer wont start. When I try to start it every thing goes blank. I twist the battery cables and everything pops back on .
First does the battery have good charge (12v). Does the wire running into the battery terminals have complete contact with the terminals? Sometimes the wiring into the terminals fray and or slide out away from the terminal housing. It could be a few things but try those first
Nov 02, 2016 | Mercury Cars & Trucks
I'm getting ground from the positive battery cable pulled fuse after fuse individually but my tester light stayed on.
Well it would. Everything is connected to the positive battery cable including things which are working and connected to the return (the ground). Things like the clock, the radio and the ECM are permanently connected when ignition is off.
Also from the way you connected the tester, between battery terminal and battery clamp, you are measuring amps drawn. So you are measuring the amperage drain of the things which are still connected and running.
Jul 18, 2016 | Cars & Trucks
How do I reset battery on laptop for an aspire 5731
There is no such thing as a reset on a battery. The only thing you can check is if the cable inside is still connected. But after a while all batteries end their service. If unplugging and reconnecting does not change a thing, I'm afraid you have to buy a new battery for the laptop.
May 11, 2014 | Acer Aspire Computers & Internet
Battery
Might be the camera's battery terminals, not the battery itself. Take a qtip and some isopropyl aclohol and clean the terminals in the battery well of camera.
Jul 23, 2013 | Nikon D3000 Digital Camera
Battery will not stay charged
when you charge your mobile device when the batteries not empty yet it starts to destroy your battery at this point your battery has had enough the only thing you can do now is get a new battery and don't do the same thing next time.
Jul 08, 2013 | Sharper Image Audio Players & Recorders
Any special thing to do to change the battery
Take the negative cable off first, and attach it last on the new battery.
Nov 20, 2012 | 2000 Dodge Neon
Something killing the battery
check for any lights staying at night, dome lights, sun visor lights for vanity mirror, glove box lights and so on, also have the battery tested, a bad cell can cause the battetry to run itself low, any Autozone or Kragen will test the battery for free.
Nov 04, 2009 | 2001 Lincoln LS
Relay starter switch
simple thing the click your hearing is a bad connection from battery to starter or the ground
the battery posts could be coroded or frade
remove wire look for frade wire and adjust and clean on the post of battery both ground and positive make sure they have tight connection
also make sure starter has good connection this will also give you the clicking sound cause these things i decribed are just things that have a bad contact
now for the other part of clicking its not your relay cause obviously the power is making it but not much to turn starter
other things that can be wrong
starter silennoid bad
bad cell in battery even when the battery tester says the battery is good a dead cell wouldnt show
alternator not charging battery
bad ingnition coil
this are a few things that would run down and give bad battery click check with top of this help with the cables first this will probably be the cause
Jun 04, 2008 | 1990 Mercury Cougar
Problem During Boot-Up
several things it could be but im going to look at the obvious the battery and cord hook up
laptops when plugged into contstant 120 power the battery is supposed to go into stand by mode and shut battery off so power dont leak into battery
if you have low battery with it plugged into 120 the comp will still think the battery is powering the laptop if battery dead then comp shuts down lack of power
other thing is somehow you caught a virus that reboots comp from dos screen mode
the main thing i always ask is what was the last thing that happened before it did what its doing now
example= was there a power surge pop up screens ect.
May 09, 2008 | Toshiba Satellite A75-S231 Notebook
12 people viewed this question
jasbo
jasbo
