Question about Garden
Stihl 015 chainsaw-screeching sound when running? just put a new pull cord on it.
SOURCE: new ms230 stihl chainsaw won't start
Sounds like its flooded pull the plug and run pull it a few dozen times to dry it out. then try again
Posted on May 27, 2009
  • 6 Answers
SOURCE: unable to crank Stihl 034 chainsaw because pull cord jams.
i had the same thing with a stihl hedgecutter its a part in the centrefruge that locks if you pull to hard pull slow and let all the cord come out let it in half way full choke on start just where it used to lock and it will start . the bad news .it wont last for long before you smash the wheel thats plastic and if its over about 5 years old they dont have a replacement part hope this helped
SOURCE: Stihl 015 Chainsaw - Change Pull Start rope
You have 3 screws to take out. 1 by the trigger and 2 on the side cover ( one on top and 1 on bottom).
The first thing you want to do is remove spark plug. After plug is removed carefully separate the housing paying attention not to lose the little spring holding the trigger when it comes apart. You can do this with the bar/chain on, but easier to handle without it. After it comes apart you can remove spring clip holding flywheel on. Be careful to lift the flywheel straight up slowly making sure the coil spring does not come up with the flywheel. If you just move it back and forth a little while moving the flywheel off the shaft. Take the rope off and measure it. I think its about 18" but try to measure the one on there. Make sure you knot the rope leaving a small tail so when the knot is tightened it has a little room to move without coming undone.After you wind the rope (clockwise) leave about 1/2 '' of rope sticking up in the notch on side of reel . Slide the wheel down and make sure the bottom notch on wheel is going to engage the coil spring when the wheel is turned.Replace spring clip on the shaft. If you have a problem with the clip, you may not be down far enough with the wheel. Turn the wheel about 1 1/2 to 2 full turns putting tension on the spring and making sure the rope sticking up is close to the the hole you need to string it through to tie in the handle. After you feed the rope through the hole (making sure you are adding more pressure on the spring as you pull the rope out, enough rope to work comfortably with the handle I take a fat bladed screwdriver and stick it down in between the wheel and housing to stop it from unwinding. Then string it through the handle with the same kind of knot used for the flywheel. After your handle is secure you can remove the screw driver and see how it works before re-assembling. Putting the housing back together requires patience making sure the housing fits over the flywheel and trigger area goes together nice.
Tips: If you need aid in stringing the rope through the handle I take about 6" of electrical tape wrap it around the end of the rope about 5 times and make sure as you wind the tape is moving towards the end of the rope and you can have a tail off the end of the rope to send through the handle. Good Luck
Rob
Posted on Jun 11, 2009
rwvanlue
  • 486 Answers
SOURCE: how do I wind a stihl ts400 pull cord
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Posted on Nov 21, 2009
SOURCE: Stihl Farmboss - cord will not move
try taking plug out to see if it turns then.if not take off pull cord assembley to see if something has come loose and jammed flywheel, failing that could possibly have snapped the piston ring and jammed. oh yes one last thing check clutch if you have chain brake on and clutch is jammed obviously wont turn.
Posted on Dec 24, 2009
I need a choke lever for a Stihl 015 AV chainsaw. Could you tell me where I might find one?
Many parts for these saws are obsolete due to age. If not available at local Stihl dealer check online for Ron's saw shop. He does a lot of obsolete parts.
Dec 28, 2016 | Stihl Garden
How can I obtain a copy of the stihl schematics for the Stihl arborsaw 015
Stihl, like most makes, is online. Go to Stihl site and search for your model.
Aug 18, 2014 | Garden
Stihl 015 chainsaw
Adjust the air/fuel mixture. Look at your owners manual or online because it gets a little tricky because of climate changes.
Aug 12, 2014 | Stihl Garden
Pull cord works; but does not engage the crank
when you pull the cord the motion pulls out 2 pins that ingage the clutch. Some times when to much oil , dirt and wood dust gets in there it sticks. Some times I just clean it and the spring out and sometimes they are worn out
Jun 05, 2014 | Stihl 015 Chainsaw Starter Pully
How to remove the clutch assembly on a stihl 015 AV
Remove spark plug.
Use a piston block to stop the piston rising.
Remove the chain sproclet cover.
Turn the clutch with a socket clockwise to undo.
Dec 11, 2012 | Stihl Chainsaw Hedge Trimmer Clutch 015 Av...
My Stihl 015AV leaks oil from the oil pump area. Any ideas? I've examined the pump, the gasket and the case and cannot determine the actual source of the leak.
This is an international collection of chainsaw enthusiasts with a few 2-cycle mechanics thrown in for good measure.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This thread is discussing an oil leak on a Stihl 015; join in.
http://www.arboristsite.com/showthread.php?t=114962&highlight=stihl+015+oil
HTH
Lou
Jan 16, 2010 | Garden
What will a stihl 015 chainsaw do if one of the springs on the plastic deals on the flywheel are broke? would it cause the saw to rev then idle down. if not what would cause that
the plastic pawls on the flywheel catch the starter pulley to turn the engine over when the starter is pulled. the spring hold the pawls in, centrifugal force holds them out when the engine is running. the one that is broken may not catch and allow the starter to skip. That is an old saw and the fuel line may be collapsing due to being softened by the fuel.
Jan 11, 2010 | Garden
New ms230 stihl chainsaw won't start
May 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
29 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
