Question about Saws
Removing a broken blade from bosch 1581avs jigsaw
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
SOURCE: Changing the blade in a bosch pst 65 pae corded jigsaw
Pull up the knob on the front at the top of the machine and push the yellow bit forward. Theoretically you should turn the knob anticlockwise three turns but it doesn't seem to make any difference on my one. Then take hold of the blade, ease it forward and turn through 90 degrees. You should then be able to pull it out. Replacement is, as they say in all the best manuals, a simple reversal of the procedure. When you are turning the knob clockwise this time it's supposed to click in place but my one doesn't do this and still seems to work.
Best of luck
Gavin
shameerariff
  • 89 Answers
SOURCE: Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Posted on Jul 28, 2009
  • 548 Answers
SOURCE: bought a jigsaw a bosch pst 54e how do i change
In the handle directly over the blade is a deep hole. You insert a long thin bladed screw driver into this hole all the way down. Twist slowly and it will locate with a screw. Undo the screw and then twist the remaining piece of blade 90 deg and pull. Replace new blade in the opposite way. Twist it so that the cut is to the front and then tighten up the screw. Do not tip up the unit while doing this as the screw might drop out and you might loose it
Posted on Sep 24, 2009
Testimonial: "thanks.did the trick.use you again thanks"
rowdy45176
  • 2176 Answers
SOURCE: WANT TO FIND PARTS LIST FOR BOSCH PST 54 PE JIGSAW
you can trying going to Boschtools.com and you will need the exact model number, the parts list section is on the left hand side of the page towards the bottom.
Posted on Jan 28, 2010
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
I have an old bosch 158IVS uh, what do you call a little reciprocating saw? jigsaw? anyways i can't for the life of me figure out how to change the blade. i've undone every screw. opened up the motor...
well the sawzaw will be drastically different from the jigsaw, but the jigsaw will have either a round twist lock that needs to be turned a little to remove the blade, or two screws that hold a flat plate that clamp the blade. and as for the sawzaw, it will be a twist lock, or a latch lock, the latch lock will look like a lever that needs lifted to remove the blade, and the twist lock is the same as the jigsaw.
Dec 30, 2010 | Saws
My bosch jigsaw keeps saing sideways!!!
Most Bosch jigsaws have a handle on the top of the main handle that you need to pull up and rotate counterclockwise to allow the screw to accept the blade. Insert the blade and rotate 90 degrees into position then tighten the handle and press back down into place. In the beginning it may seem like you are going to break the handle pulling it up but rest assured it will get easier as it gets used.
May 10, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Bosh pst54e instrution manual how to remove blade
Hi just wondering what the screw looks like as I have an old one of these that the screw went missing out of years ago. I'd like to replace it but need to know length and diameter of the screw if you could please?
Feb 11, 2010 | Bosch Saws
Replacing blade?
at the top and front of the saw there is a plastic handle. Pull up and rotate counter clockwise 1/2 or full turn maybe more. remove and replace blade and rotate clockwise (handle) and push it back down.
Jan 03, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Milwaukee jigsaw with blade change problem
a new tool will cost you about 170. You could look for a used on on craigslist.
Apr 21, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Saws Logo
46 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
