Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White
Dryer not drying
Took off dryer vent from the back and ran the dryer. Hot air is coming out of the back of the dryer. Vent is not clogged because it is brand new. Put clothes inside the dryer, ran for 15 minutes, opened and immediately checked clothes. No heat coming from tub and clothes were cool to the touch.
    Top Expert:
  • 14,553 Answers
Not a major appliance expert--but if the situation is as described with hot air out vent but not in the drum where the clothing is it seems to me you have a blockage between the drum and lint filter to where it reaches the vent tube---they do make long flexible brushes for this-----a suggestion: if you have a compressor try forcing air down from the lint filter with the vent tube removed to see if the blockage is there and will clear or not.
A blockage can be a fire hazard so if you do not find it have a tech out.
Posted on Dec 04, 2012
  • G. Fig Dec 06, 2012
    So, I pulled the front off of the dryer. Underneath was completely covered in lint. I used an air compressor to blow out the lint and then vacuumed. I started the dryer to observe and noticed that it would light initially for a couple minutes. After that I would see a glow as if it was attempting to ignite but at never ignite. Any idea what the problem could be?
  • 686 Answers
SOURCE: My ultimate careII dryer will spin but clothes are
REMOVE THE BACK PANEL AND THERE YOU'LL HAVE ACCESS TO YOUR HEAT ELEMENT CHECK IT FOR A BROKEN COIL AND ALSO CHECK YOUR THERMAL FUSE.
Posted on Apr 10, 2009
  • 190 Answers
SOURCE: Dryer not generating heat and drying clothes...
Dear customer,
                We recommend you to do the following checks when your dryer isnt generating heat..
  1. Check for proper air flow
  2. Test the safety fuse
  3. Test the thermostats
  4. Test the centrifugal switch
  5. Test the timer motor
  6. Test the heating element.
Thank you.
Posted on May 09, 2009
  • 64 Answers
SOURCE: dryer wont dry clothes
Vents can fool you sometimes they seem to be ok but still cause problems. Try running with vent unhooked from machine one time and see if it works ok.
Check for leaks air leaks around the door or anywhere else.
Posted on Jun 10, 2009
  • 67 Answers
SOURCE: the dryer is not staying hot to dry the clothes.
Sounds like the overheat is tripping, usually due to lint clogging the exit inside the dryer and inside the pipe.
Posted on Jun 30, 2009
miket756
  • 2702 Answers
SOURCE: NOT ENOUGH HEAT TAKES 3 TIMES THROOUGH TO DRY
i would check the thermostat first then change the igniter
Posted on Apr 13, 2010
Testimonial: "i will try that ty so much i will get back to you"
Dryer has Heat but NO AIR
Many of these have a belt driven blower wheel, could be a broken belt or it came off, There was also a bulliten out on several models where the blower wheel would come loose from the drive shaft, the fix was to re attach using a medium body thread lock compound so it would not unscrew again.
Sep 25, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer gets hot but does not dry. It seems to keep the moisture in as of there isn't any air flow. I cleaned out the vents and air duct but still wont dry
This definitely sounds like a clogged vent. 1) disconnect the vent from the back of the dryer. Turn the dryer on and make sure your getting good air flow from the vent outlet. 2) if the air flow is good then your definitely have a vent that is clogged between the dryer and the outside of the house. This is the most common cause for the dryer to not dry the clothes.
Jan 13, 2011 | Dryers
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer not drying loads properly.
You need to clean the vent ducting from the point where it leaves the dryer to where it exits your home. The reason the dryer performed better was because it was not meeting any resistance from the ducting to push air through the exhaust on the back of the dryer. You obviously have a clog, kink, excessive bend, or a run that is too long. If you haven't had your vent ducting inspected or cleaned in a while, now would be a good time. In addition, the fact that your dryer became excessively hot WITH the ducting attached adds credence to my suspicion that your ducting is clogged or obstructed in some way. Without proper air flow the dryer will actually overheat to the point of failure. Usually the Thermal Cut-Out (also known as a Thermister) will blow. This component is designed to blow like a fuse in the event of an overheat condition and must be replaced. Running your dryer in an overheat condition not only will damage the appliance, but it can become a fire hazard. I would recommend a thorough ventilation inspection and cleaning. Make sure you are using the metallic semi-rigid ducting and NOT the plastic ducting. The semi-rigid resists crushing, kinking, is heat resistant and resists intrusion by rodents. If you have questions about anything I've explained to you, please contact me and let me know. I hope this helps.
Feb 10, 2009 | Frigidaire GLER642A Electric Dryer
Dryer not drying clothes properly
Replace the vent tubing, sounds like something is stuck or it is crushed somewhere. So replace it for about 5 dollars and see if that works. It should since you disconnect the hose and it drys right away
Feb 10, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
A lot of moisture in the exhaust line of dryer...
thats easy the moisture from your clothes ,,and the outside air,,where ever you live its a lot of moisture in the air,,now the cold air from outside is coming back in dryer and the hot moist air is trying to get out,,bingo condensation,,in your dryer exhaust vent tube ,,hince all the water,,,,now to fix that ,,we need to dump all the water from vent exhaust tube ,,you may need a new one because it will mostly rot...and check the flap or put a window exhaust kit on the house or window,,to stop air flow from coming back in the dryer ,,and where done..onthejob
Jan 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer not heating
THE PROBLEM IS YOUR WALL VENT CLOGGED OR THE BACK OF THE DRYER VENT HOLE IS CLOGGED,IT KEEPS THE MOIST HOT AIR IN THE DRYER SO YOUR CLOTHS TAKE FOREVER TO DRY,THEY MUST BE CLEARED FOR THE DRYER TO WORK AGAIN-MIKE
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Jan 09, 2007 | LG DLE2532W Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White Logo
107 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
