Question about Hobart Dishwashers
Hobart chh60d dishwasher
Not washing clean
3 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: HOBART FX-20 dishwasher out of order
There is one glued to the lower panel on the inside. Hobart is very tight lip'd when it comes to getting any info from their web site. Best I can do, sorry.
Posted on Jan 25, 2010
  • 119 Answers
SOURCE: Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Posted on Jul 16, 2010
Hobart dishwasher making loud grinding noise in wash cycle
suspect you have something in the wash pump.that has got through the filter or when you cleaned base filter it dropped down the hole,when you had the filter out,could be a small piece of glass or a chip of a cup, if you also think the same ,suggest search on u tube REMOVING OBJECT FROM A HOBART WASH PUMP or
removing objects from a dish washer pump, or pull mains plug out gain access to wash pump, screwdriver in back pump shaft ,turn and you will fill if there is something in pump, some times you can vac out through base filter using a wet vac.
Nov 23, 2016 | Hobart Dishwashers
Why would a Hobart AM14 Dishwasher just fill and not wash
It seems to have failure on the lever sensor .
check the float , probe and switch assy.
Apr 11, 2015 | Hobart Dishwashers
Hobart lx30h leaking from bottom
This is a testing for the post on this web site, not a solution.
Mar 27, 2014 | Hobart Lx30h Commercial Dishwasher
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Jan 20, 2010 | Hobart 24 in. LXIC-5 Built-in Dishwasher
How much delime agent should I use to clean the system in a Hobart LXI-H?
Depending on how often you delime the dishwasher use 2 cups.The delime light will come on after 1000 cycles set from factory default.If the delime icon is lit and beeps,turn the unit off.
Push and hold the delime/wash button and on button for 5 seconds and youll be in delime mode.
The unit will fill and heat up and display "add delime".Open the door add the delime and press the wash button.The dishwasher will run for 5 minutes then rinse and drain twice then shut off.When you turn it back on the delime icon will be gone.I'm a hobart tech and repair these dishwasher often,any questions let me know and please rate me,Thanks.
Nov 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher lx 30 h
Did the clean light indicator blinking over n over? check the element wire harness connector. If disconnected fix it and run your dishwasher again.
Also you may check the continuity of your heating element.
Jul 23, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Dishwashers Logo
21 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
