Question about Sewing Machines
Hook Up Does not work - Sewing Machines
  • Sewing Machines Master
  • 1,564 Answers
Look for a replacement online.
Posted on Dec 07, 2012
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
I'm crocheting round doilies. I'm using 4 ply wool and a 2.70 hook.The work gets very "wavy" after a few rounds. Do I need a bigger hook?
Sounds like you may need a smaller hook. If the project is getting ripply instead of laying flat, then there is too much "fabric."
May 25, 2017 | Sewing Machines
Can you please tell me what the crochet abbreviation (esc) means?
extended single crochet
  1. Step 1: Insert hook from front to back through stitch to be worked.
  2. Step 2: Yo hook.
  3. Step 3: Draw loop through fabric.
  4. Step 4: Yo and draw through first loop only, forming a chain stitch.
  5. Step 5: Yo and draw through both loops on hook.
Feb 20, 2017 | Sewing Machines
I misunderstood the cleaning instructions and removed the screw holding in the hook race.
It should just slot in one way only. Try it 180 Degrees around.
If the timing between the Needle and the hook is wrong, when the needle is about to lift, set the hook to be about 3 degrees off the needle line. This position may need tweaking but is usually about right. Thread the needle and manually turn the machine. The needle should lift and the cotton should loop for the hook to pick up.
Jul 10, 2016 | Sewing Machines
Bobbin case is stuck in hook race cover. The bobbin case release lever doesn't seem to be working properly, and case won't pop out of hook race.
1. Try to get the hook towards the front.
2. Remove the bottom.
3. From the back of the hook you will need a wide item to go through the hole of the hook. This is so that you can tap it while it is pushing the bobbin case.
4. You may add a little extra oil to help.
5.. Be patient so that you don't bend the hook or the race.
Because the bobbin case is in at an angle it will have to be forced out. Try to see which way it is cocked so that you can place your tool against it while tapping it.
Apr 08, 2015 | Sewing Machines
Putting oil in my sewing machine
Take out the bobbin and then release the hook retainer (black plastic part that the bobbin goes into), but pressing the catch on the inside left-hand-side of the bobbin door. The hook retainer should then drop and the hook can be taken out. Clean around the inside of the hook race (the circular metal part of the chassis that the hook fits in) using a cotton bud and make sure that the small groove that runs around the inside of the hook race is completely clean. Take your oil dropper and put a single drop of oil at the bottom of the hook race - you should see it 'wick' around the groove slightly - this tells you you've put it in the right place. Replace the hook, making sure its properly seated and press the hook retainer back into place firmly until the catch on the left clicks. Rotate the handwheel once to ensure that the oil is distributed and replace the bobbin. You're advised to make sure the needl is returned to the correct position for the automatic threader to work, either by pressing the needle up/down button twice or dabbing the foot controller so a complete revolution is done by the machine. You should oil the hook race every 3-5 bobbins-worth of thread. Hope that helps.
Mar 22, 2012 | Sewing Machines
Bernina 130. The upper needle is working but it does not seem to be abLe to catch the bottom thread. Had this machine for 12 years so I know how to put the bobbin in. Any ideas?
Firstly, I assume you've cleaned-out under the stitch-plate and after removing the bobbin, have removed the hook/shuttle, cleaned the hook race and given the hook race a drop of oil. Whilst you've got the hook/shuttle out, just check that the point is not damaged. Also, if you've got the lightweight hook/shuttle often fitted to these machines (it's black plastic with a metal outer/point), make sure there's no needle damage to the plastic - sometimes this can catch the thread as the hook rotates, preventing the loop from being picked-up. After doing that, check if you can sew straight stitch with the needle in centre, fully left and fully right. If it works in one location but not the others, there could be a number of issues such as timing/synchronisation or possibly the needle bar is offset front-to-back so that there's too large a spacing between the needle and hook.
Nov 13, 2011 | Bernina Activa 130
Can't reassemble the shuttle/hook in Singer sewing machine - it is Model # 1120 - an inexpensive machine but works great. It jammed and I released the retaining clamps (?) and the other little parts fell...
Turn the hand wheel until the hook race is in the left position..replace the hook to right side...replace the hook race cover..smooth end to the bottom..and snap back the hook retaining arms...now ready for inserting bobbin case...Good Luck
May 29, 2009 | Singer 1120 Mechanical Sewing Machine
Pfaff tiptroni6122, the thread loops up on the bottom of material
Sounds like the hook timing is off. You don't need a new hook but you may need a new position finger. If you are unfamiliar with working on sewing machines then it needs to go to the shop. This is a great machine and is worth keeping up. Pfaff doesn't make the all metal hook anymore which is a shame.
good luck!
Feb 04, 2009 | PfaFF Hobby 4260
W3300 hook and needle
I had many broken needles before I put my thread on a thread stand behind my machine. I found that the thread was winding around the thread post and causing a jam and thus, breaking my needles. This solution worked!
Oct 30, 2008 | White Sewing W3300 Computerized Sewing...
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
