Question about Bosch Tassimo TAS 4012 Coffee Maker
Power is working but no brew lights come on after unit is turned on. is there a reset button? or a solution to fix this?
"brew unit block" medium cup in service mode dont work only the small cup works
When the alert came up- Brew unit blocked- this is before you started taking things apart, A, were you able to remove brew unit, Yes or No?
B, after turning power on and then off, Did the machine try to reset brew unit to home position Yes or no?
If Yes were you able to remove brew unit?
Aug 18, 2014 | Miele CVA615 Espresso Machine
Coffee pot not brewing
do you get any display?
Aug 09, 2008 | Cuisinart Coffeemakers
Keurig not brewing
Our unit (the mini) would only blink red but would not brew. It didn't make any noise and seemed like it was dead. To fix this, leave the unit plugged in but powered off. If you haven't already done so, add water to the top of the unit and then open the pod holder so that the water flows into the internal storage tank. Hold the brew button in (don't let go until it is done brewing) and the light will turn on - after a while it will start brewing. Let go of the button once it has finished brewing. According to a Keurig rep - this problem is often caused by using cold water straight from the fridge.
Sep 17, 2013 | Keurig Coffee Makers & Espresso Machines
Keurig Elite B40 not responding after "add water" and "heat" and "power" lights start flashing
Unplug the unit to reset it. That will give you a short term solution. I had the same problem, my machine is only 4 months old. They sent me a new one. I was told that there is no way to fix the problem for good. The unit is defective. Luckily I registered my machine right after I got it, and I kept my receipt They sent me out a new one, free of charge! It took about a week to get it..
Aug 21, 2012 | Keurig Elite B40 Coffee Maker
Brew unit blocked message The brew unit removed and switches jumped, motor turns message still blocked brew unit . what could it be and ways to tests.
I had the same issue. Very difficult to fix. You must remove brew unit and reset the machine while apart. You must trick the machine to think brew unit is installed and door closed. Look at door and brew unit and use screwdriver or butter knife to engage machine and run through cycle to reset.
Jul 09, 2011 | Starbucks Saeco Italia Digital Barista...
Brew unit and waste unit in place, brew unit is blocked
For Brew Unit Block:
  • Turn Off
  • Hold small coffee & hot wate atthe same time
  • Turn on with light (numbers sill appear)
  • Hold medium coffee util arm returns to normal position
May 27, 2009 | Miele CVA615 Espresso Machine
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Mar 21, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Brew cup stuck unable to get out
If you open the door and take a flashlight, light in the front/middle of the brewing unit. You will see a little screw, take a screwdriver and loosen it, bend little on the little plastic above where the screw was and pull out the brewing unit.
When you have the brewing unit out then you need to reset the machine and brewing unit.
To reset the machine you have to turn off your machine, open the door.
Look in the down left corner, you will see a hole, look in the middle of the machin you see another hole and in the upper right corner.
put a screwdriver or similarly in the left corner and in the middle of the machine, turn on the machine and put another screwdriver in the upper right corner. hold it in place to the machine not get any noise more.
To reset the brewing unit, first put the plastic back again (that one you loosen with the screw first).
If you look back on the backsida of the brewing unit, in the middle you will see a plastic that looks lika a handle, force it down and you will see all the other parts will move around little. Turn it to you can see the little mark on the front goes to the N mark.
Best regards
/Mirran
Jan 29, 2009 | Saeco Vienna De Luxe Espresso Machine
Miele brew unit jammed and brewunit block is being displayed
There is a third solution. The brewunit drive motor has three contact switches that indicate home, preset (loading grounds, I assume) and make espresso. The problem is the three contact switches are all on one circuit, so the microprocessor knows a limit switch has been reached, but it doesn't know which one. The programming obviously assumes the limit switches are reached in the correct sequence. In my case, the microprocessor thought the brew unit was in home position when it was in the make espresso position. Miele technical support recognized this immediately, so it is a common problem. The solution is to remove the top panel of the unit, unplug the unit, unplug JP34 on the microprocessor board (four wires, red/yellow/brown/black, in the middle back edge of the microprocessor board). Plug in the unit, put it in maintenance mode, and press and hold the medium coffee button for several seconds. This will move the drive motor past the current limit switch. Plug JP34 back in, plug in the machine, and put it in maintenance mode. Press and hold the large coffee button for a second or two, maximum. Open the machine, and look at the brew unit drive male gear in the main machine as compared to the brew unit female gear. It will take several tries to get the male/female gears to match so you can plug in the brew unit. Once this is done, and the brew unit snaps in place correctly, place the machine in maintenance mode one more time and press and hold the Medium Coffee button to reset the microprocessor with the limit switches. You should be back in business!
Nov 25, 2007 | Miele CVA615 Espresso Machine
Bosch Tassimo TAS 4012 Coffee Maker Logo
27 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Andrew Taylor
Andrew Taylor
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
